engine mods for low-end torque - Subaru Impreza WRX STI Forums: IWSTI.com
Go Back   STI Forums > > > engine mods for low-end torque
Old 02-28-17, 04:45 AM   #1
'12STi70
Becoming A Contributor
'12STi70 is an unknown quantity at this point
Default engine mods for low-end torque
So I have had a basic stage 2 package done to my '12 Hatch, ID 1000s, TGV deletes, air pump delete, turbo inlet, turbo back and pro-tune.
It is much better than stock but I want to know if there are engine mods that will specifically increase torque before the turbo spools?
I don't necessarily want a sharper torque rise, I want to move the entire torque rise to the left (on the dyno graph).
I'm more familiar with V-8 engine mods. If you want more low-end torque from a SBC you bore and stroke it and it becomes a 383 and a low-end monster. Longer stroke = more torque whether it is a gas or diesel.
Is there a stroke kit for these 2.5 subarus? Will a piston change effect low-end?
thanks for any opinions
'12STi70 is offline
Old 02-28-17, 06:00 AM   #2
mheyman
Feedback Score: 4 reviews
Fav Mod: Camber Camber Camber! Power! Wide ratio gearing! The rest is just support :)
Default Re: engine mods for low-end torque
No, not really. The turbo must spool before the car gets into its power band.
Despite a common misconceptions that cars should have lists of low end torque, it is not needed to make a fast car. In fact it really isn't good for its bearings. What works involves torque, rpm and gearing.
Your question makes me wonder whether you are driving in an rpm range where an STI is happy.
That's not normally accepted as stage two. Stage two is historicall DP and tune. 2+ adds an intake.
Generally in an STI you build for power from 3500 - redline with the intention of not having that 3500 get higher - or not to much higher - because high power builds often are.
Actually yes, and if you are really going to build an engine you will have that option. I't not going to work miracles on its own though.
The one thing you should look into is E85. Guess I didn't write that first because though it will get you more torque it will be after spool. It will get you more torque.
IMHO, to justify its' price, the S209 needs to perform at least as well as my moderately powered 05 built beater, and even that might not convince me to buy one cause my next STI isn't likely to be moderately powered.
mheyman is offline
Old 02-28-17, 10:42 AM   #3
blacknblue06STI
Account Inactive
Car: Black, 06' STI
Fav Mod: ACT Monolock
blacknblue06STI has a spectacular aura aboutblacknblue06STI has a spectacular aura about
you can degree the cams to change the initial base settings and change the torque curve to the right or left.
There are several adjustable cam gear suppliers,,,crower has been around since the 60's so I'm sure its quality stuff...heres a link,
BC8860 Brian Crower Adjustable Cam Gears 2002-2007 Subaru WRX / STI - Horsepower Direct LLC
blacknblue06STI is offline
Old 02-28-17, 03:11 PM   #4
8cd03gro
Advanced Mastery Level II
8cd03gro is a jewel in the rough8cd03gro is a jewel in the rough8cd03gro is a jewel in the rough8cd03gro is a jewel in the rough
Buy a V8
8cd03gro is offline
Likes 1 Dislikes 0
Old 02-28-17, 03:21 PM   #5
'12STi70
Originally Posted by 8cd03gro View Post
Buy a V8
thanks for that. I was just asking a question to see what is out there.
I have v-8s in my trucks.
'12STi70 is offline
Old 02-28-17, 03:23 PM   #6
yamahaSHO
BROtuner
Feedback Score: 7 reviews
Car: 2005 WRB
Fav Mod: Equal Length Header
Buy a V8
This is the answer.
A low compression 2.5 liter will not have torque before the turbo starts cramming air into it.
jaz|TUNING
yamahaSHO is offline
Old 02-28-17, 03:27 PM   #7
8cd03gro
I'm just giving you the answer to your question. Regardless of what you do, this is still going to be a 4-cylinder with a lot of plumbing to and from the turbo. It will never have good low end torque. There are certain setups that will have good low end for an STi, but you're never going to make gobs of torque at 2,000rpm like you can with a larger displacement engine. An E85 tune will help. A stroker setup would help, but you're opening a huge can of worms there. If it's low end torque you seek you should really skip spending a bunch of money because it's not going to happen on this platform.
8cd03gro is offline
Likes 1 Dislikes 0
Old 02-28-17, 03:34 PM   #8
'12STi70
Ok, well thanks. that is the info that I am looking for.
I know it isn't going to make V-8 low-end, I was just trying to figure out what could and couldn't be done. The shop that did the work so far has a flex fuel kit but I don't have E-85 readily available.
'12STi70 is offline
Old 03-01-17, 04:38 AM   #9
Jay11STI
Feedback Score: 2 reviews
Car: 2011 SWP STi Sedan
Jay11STI has a spectacular aura aboutJay11STI has a spectacular aura aboutJay11STI has a spectacular aura about
The easiest way to get more hp and torque out of these cars are equal length headers (ELH) and E-85 fuel. Both will require supporting mods and work really well together.
Jay11STI is offline
Old 03-01-17, 07:27 AM   #10
Voodoo Rufus
Fav Mod: Driver Mod
Voodoo Rufus will become famous soon enough
Not so joking: high compression pistons.
Totally joking: TD04 turbo.
Meth injection might help, too.
Voodoo Rufus is offline
Similar Threads
The Official STi engine Venting, A/O Separators, and Catch Cans Thread!! JZeezSTi 2.5 Liter/Litre Factory Motor 1817 10-23-18 06:49 AM
Whats the most benefical mods for the engine??? racefreak156 2.5 Liter/Litre Factory Motor 21 11-27-12 12:36 PM
help me understand the concept of running dccd in rear in highway erichyung Drivetrain Components 41 07-30-07 05:33 PM
Crawford Burnout! AGUSTA Video Collection 38 07-04-07 11:33 AM
