engine mods for low-end torque - Page 3 - Subaru Impreza WRX STI Forums: IWSTI.com
Go Back   STI Forums > > > engine mods for low-end torque
Old 03-06-17, 09:50 AM   #21
mheyman
Feedback Score: 4 reviews
Fav Mod: Camber Camber Camber! Power! Wide ratio gearing! The rest is just support :)
Default Re: engine mods for low-end torque
Originally Posted by '12STi70 View Post
talked with my builder today. For a bottom end rebuild to SAFELY build early torque they wanted a HUGE amount of $.
So awaiting a quote for their flex-fuel kit, ELH and up-pipe.
Thanks for the info everybody
Thread never quite got there cause your never going to have much torque until after your turbo spools - and nothing you will realistically do is going to change that "much" - even if our bottom end would hold up. You add power where it already exists - particularly at the high end where the stock engine runs out. If you add that much power you're probably spending that 'HUGE" amount and are still not planning on the torque you desire.
Back to V8 posts
IMHO, to justify its' price, the S209 needs to perform at least as well as my moderately powered 05 built beater, and even that might not convince me to buy one cause my next STI isn't likely to be moderately powered.
mheyman is offline
Old 03-06-17, 11:24 AM   #22
jerfodor
Advanced Contributor Level 1
Car: 11 STI JRTuned 2+
Fav Mod: Killer B headers
jerfodor is on a distinguished road
Originally Posted by Blk04SR View Post
The ELH is well worth it for the low end torque you are looking for.
agreed moves the whole dyno graph to the left. I have Killer B headers pretty much stage 3 stock turbo and I am sure there are a lot of cars with way more horsepower.
Torque at 3600rpm was 338.15 and max hp 287.45 at 5500rpm
I compared my dyno graph with others that make way more HP but there torque is maxed way above the 3600rpm my setup has. After getting a new ACT HD clutch it is spooky fast I think the clutch had been slipping when I got tuned so robbed me of some power . You may also have to look into budgeting a new clutch as well torque kills clutches. This setup makes merging on the freeway quite easy. Hope this helps you out.
jerfodor is offline
Old 03-07-17, 05:14 AM   #23
'12STi70
Becoming A Contributor
'12STi70 is an unknown quantity at this point
thanks all
definitely going with headers, flex-fuel kit and up-pipe.
I have been quoted a Tial MVR EWG as well, is something that I really need with a stock turbo? Along with previous mods, on E-85 car should be close to 350hp/400tq on stock turbo. Def the limit of the stock turbo.
If I do get the EWG I am going to have them plumb the waste gas back to exhaust. Does that also make it not worthwhile?
'12STi70 is offline
Old 03-07-17, 08:08 AM   #24
mheyman
Makes it tolerable If its plumbed well the difference will be small.
mheyman is offline
Old 03-07-17, 12:28 PM   #25
Blk04SR
Advanced Contributor Level 2
Car: CBS 14 WRX STi SOLD
Fav Mod: ELH & E85
Blk04SR is an unknown quantity at this point
thanks all
On E85 (content being 80%) I made fat torque to the wheels from 3k-4k it was 430 ish wtq. The car is tuned conservative as well.
Just and FYI...with no E85 on California Pump 91 it make 350 ish wtq in that RPM range.
Blk04SR is offline
Old 03-08-17, 06:59 PM   #26
2bfi
Advanced Contributor Level 3
Feedback Score: 2 reviews
Car: 2011 WRX STI
Fav Mod: Lightweight flywheel
2bfi is on a distinguished road
This won't add more torque, but will feel the same.
You can lighten rotating mass. The easiest way is to go for lighter wheels. This gave me the biggest gain. Next would be a lighter flywheel. I use a 13.3lbs Exedy lightweight flywheel. No CELs ever.
Other rotating parts that can be lightened and their disadvantages are:
Crank Pulley - Lots on controversy whether or not it is a harmonic damper. At high rpms, I noticed more vibrations and doesn't pull as hard. I took it off after a few months.
CF Driveshaft - Not cost effective. The effect is not as great as the others because of the low polar moment of the removed mass.
2bfi is offline
Likes 1 Dislikes 0
Old 03-08-17, 09:35 PM   #27
Voodoo Rufus
Fav Mod: Driver Mod
Voodoo Rufus will become famous soon enough
2 piece brake rotors would also help with rotating mass.
Voodoo Rufus is offline
Old 03-08-17, 10:27 PM   #28
RussellX
Car: 2019 Red WRX STi
Fav Mod: Cobb Accessport V3
RussellX has a spectacular aura aboutRussellX has a spectacular aura aboutRussellX has a spectacular aura about
Originally Posted by mheyman View Post
In fact it really isn't good for its bearings.
Does that mean the increased torque can also be the cause of rodknock???
RussellX is offline
Old 03-09-17, 06:14 AM   #29
mheyman
Truth is no one has suggested they understand the STI bearing issue, but we know they fail "too often" and it is catastrophic. We also know lugging any engine is hard on bearings and it should be avoided. Lugging an engine under boost is the worst for that engine.
Not lugging may not save your engine, but at least you'll know you didn't unnecessarily shorten their life.
Lugging is poor driving technique. If you have boost you have it because you need torque. You'll gain effective torque by downshiftin to raise rpm. A stock STI sweet Spotify 3500-5800rpm, but if you are accelerating hard you want to downshift into the lower part of that range - say 4000rpm.
mheyman is offline
Old 03-09-17, 07:35 AM   #30
liltoua
Car: Black 98 2.5rs
Fav Mod: 6 spd
liltoua is an unknown quantity at this point
Here you can do this....Compound Charged. I took this picture at the Tokyo Auto Salon in 2016.
liltoua is offline
Similar Threads
The Official STi engine Venting, A/O Separators, and Catch Cans Thread!! JZeezSTi 2.5 Liter/Litre Factory Motor 1817 10-23-18 06:49 AM
Whats the most benefical mods for the engine??? racefreak156 2.5 Liter/Litre Factory Motor 21 11-27-12 12:36 PM
help me understand the concept of running dccd in rear in highway erichyung Drivetrain Components 41 07-30-07 05:33 PM
Crawford Burnout! AGUSTA Video Collection 38 07-04-07 11:33 AM
