Questions about track day - Page 2 - Subaru Impreza WRX STI Forums: IWSTI.com
Go Back   STI Forums > > > Questions about track day
Old 05-31-16, 07:01 AM   #11
revilingfool
Advanced Contributor Level 3
Car: 12 LR STi
revilingfool will become famous soon enough
Default Re: Questions about track day
Originally Posted by BlueScooby View Post
wow thats high. I ran 33-35 hot on my MPSS which was way grippier than 40+psi...
Ya, i would agree, but i did have a set of hankook evo that liked it up around 40. i wouldnt start there though.
revilingfool is offline
Old 05-31-16, 05:38 PM   #12
pawlex
Becoming A Contributor
Car: Silver '12 STi
Fav Mod: COBB AP
pawlex is an unknown quantity at this point
I found when I was running mid 30's on the stock dunlops, the pyro showed that the shoulders were getting considerably hotter than the center (~20F). IMO it's easier to start a little high and let some air out if you notice your grip getting greasy.
How did you like those Pilot Super sports on the track?
pawlex is offline
Old 06-01-16, 02:54 AM   #13
TimM
Becoming A Master Contributor
Car: 2004 WRX STI
TimM will become famous soon enough
Alignment is a big variable. You will be forced to run higher pressures unless you have decent negative camber dialed in.
His first day, he should go with factory pressures and not worry about them.
Check oil, coolant, and concentrate on not crashing your car! It is a blast...then comes the fine tuning during follow on days.
153 MPH STI
Autobahn!
Stage II: 262 WHP / 270 WTQ / 12.84 @ 105.3 MPH
Stage III: 327 WHP / 12.73 @ 106 MPH
Stage IV: 412 WHP / 367 WTQ / 12.28 @ 112 MPH
TimM is offline
Old 06-01-16, 03:44 AM   #14
BlueScooby
Feedback Score: 6 reviews
Yeah higher pressures are probably needed with softer sidewalls too.
The MPSS did great! They are slightly soft for the track, but I thought they held up really well.
Make sure to bleed off air pressure after your first session, my pressure built up an additional 20psi from heat... Cold my tires were at about 20psi to have 35ish psi hot... Actually, you should probably start off with ~25psi cold and see where that takes you.
Bluescooby's 06 STI Journal
IG: BlueScooby06
BlueScooby is offline
Old 06-01-16, 10:04 AM   #15
TimM
Car: 2004 WRX STI
25 psi cold? I'd never corner with 25 psi in the tires of my semi-heavy Subaru...my cars spec is 36 factory. Bleed off the excess-yes-as you can always release...just can't put back unless the track as facilities.
153 MPH STI
Autobahn!
TimM is offline
Old 06-01-16, 11:09 AM   #16
BlueScooby
I wouldn't leave for a hot lap on 25psi tires, no... But by time you finish the warm up lap (not driving hard) your tires are likely at 30psi already and will heat up very quickly after that...
IG: BlueScooby06
Similar Threads
Track Day: Upcoming Joey G Open Track Day for ADVANCED Drivers, Aug 20 NJMP Lightning Azp Installs Sanctioned Motorsports 0 08-14-12 02:49 PM
Track Day: Upcoming Joey G Open Track Day for ADVANCED Drivers, Aug 20 NJMP Lightning Azp Installs USA - Northeast 0 08-14-12 02:45 PM
AMS 2008 Track day Schedule / Registration AMS USA - Midwest 18 09-14-08 03:13 PM
May 26th - 3rd 2007 Track day @ Dunnville Autodrome 4-8pm by KZK Canada 0 05-11-07 10:01 PM
Lime Rock Track Day Review (long) TrackRat Sanctioned Motorsports 2 04-20-04 03:25 AM
