05 STi Timing Belt Idler Pulley Torque - Subaru Impreza WRX STI Forums: IWSTI.com
Go Back   STI Forums > > > 05 STi Timing Belt Idler Pulley Torque
Old 10-06-15, 06:14 AM   #1
OldSchoolEuro
Becoming A Contributor
OldSchoolEuro is an unknown quantity at this point
Default 05 STi Timing Belt Idler Pulley Torque
Hey guys, so I was replacing my timing belt on my STi this past weekend and was looking at the FSM to see what the torque value is on the idler pulleys. It states that all four idler pulleys (x2 Smooth Pulleys, x1 Cogged Pulley and then the x1 Smaller Pulley) have a torque value of 39 Nm. Now the larger pulleys were torqued to 39 Nm, but the smaller pulley bolt was being torqued to 39Nm as stated and the torque meter was hovering at around 27-28 Nm and I was still able to turn the bolt. I backed off of it and low and behold the bolt was stretching. Luckily I didn't leave it on there or else there would have been catastrophic failure. So I am not sure if its a bad bolt or if the torque spec was incorrect. Can someone shed some light on what the actual torque value on that smaller pulley bolt is? Thanks!
OldSchoolEuro is offline
Old 10-06-15, 07:16 AM   #2
mheyman
Feedback Score: 4 reviews
Fav Mod: Camber Camber Camber
Default Re: 05 STi Timing Belt Idler Pulley Torque
The one by the tensioner?
According to alldatadiy 25Nm
mheyman is offline
Old 10-06-15, 07:50 AM   #3
OldSchoolEuro
Yes that is correct. Hmm, okay 25Nm. Guess the FSM is incorrect again...can anyone else confirm the other pulleys if 39 Nm is correct for those before I put the belt on?
Old 10-06-15, 08:02 AM   #4
mheyman
Yes the others are given as 39Nm.
mheyman is offline
Old 10-06-15, 10:11 AM   #5
OldSchoolEuro
Awesome sounds good, thanks for the feedback.
Similar Threads
Gates timing belt kit? As good as OEM? NewShockerGuy 2.5 Liter/Litre Factory Motor 35 03-06-17 06:28 PM
Gates Racing Timing Belt Kit w/ Water Pump BLOWOUT SALE!! Boston Motorsports GR-Engine, ECU, Power, Drivetrain 15 10-25-12 02:13 PM
Oil leak, residues on timing belt cover nguy3n85 2.5 Liter/Litre Factory Motor 10 09-30-12 08:08 PM
What did you torque your crank pulley down to? roninsoldier83 2.5 Liter/Litre Factory Motor 12 07-17-08 09:07 PM
