Ron Davis Radiator (w/ oil cooler) - Page 25 - Subaru Impreza WRX STI Forums: IWSTI.com
Go Back   STI Forums > > > Ron Davis Radiator (w/ oil cooler)
Old 05-06-19, 01:50 PM   #241
FourDoorFun
Active Participant
Car: Grey 2011 WRX STI
FourDoorFun is an unknown quantity at this point
Default Re: Ron Davis Radiator (w/ oil cooler)
Thanks for replying. I'm at a loss on what to do. Do you think I should post as a new topic for some more help? Do you know someone on here I could IM to get some help?
FourDoorFun is offline
Old 05-07-19, 02:54 PM   #242
jlewis92683
Advanced Contributor Level 1
Feedback Score: 2 reviews
Car: 08 Aspen White STi
jlewis92683 is an unknown quantity at this point
What are your Bearing clearances at. I have +1 mm on my bearings to allow for more oil and a 12MM pump to go along with my oil cooler. When I track my car I will be around 50PSI as well, as I push 240F+ on oil temp. had this setup for almost 5 years now with no issues.
Normal cruising I will be at 16PSI on idle and 60PSI at 2700RPM plus with oil temp around 180-190F.
jlewis92683 is offline
Old 05-08-19, 06:35 PM   #243
FourDoorFun
Active Participant
Do not know the bearing clearances. Today I tried removing the cooler from the system. I did this by removing oil lines from cooler and connecting them together with an an10 male to male. This way I can see oil pressure of the sandwich plate and oil lines. Without the cooler and oil up to full temp oil pressure will rise to between 70 and 75 psi. Pressure was while in fourth gear and pulled to 6000 RPMs. This proves I have a 20 to 25 psi pressure drop when ran through cooler. I'm at a point of uncertainty on what to do.
Old 05-08-19, 08:37 PM   #244
yamahaSHO
BROtuner
Feedback Score: 7 reviews
Car: 2005 WRB
Fav Mod: Equal Length Header
Personally, I'd put together your own cooler setup with a different core. I like Fluidyne's cores, especially their Therm-HX models as they are made to keep the pressure drop low. They are big, but work well.
I used this on my old SHO, which is almost the size of a stock GD intercooler:
My S2000:
www.jaztuning.com
yamahaSHO is online now
Similar Threads
Mishimoto Releases New Oil Sandwich Plate and Direct Fit Oil Cooler Kits! Mishimoto GD-Vendor Classified Ads 8 05-27-14 09:50 AM
Product Release! Mishimoto Direct Fit Oil Cooler for the 06-07 WRX & STI! Mishimoto Vendor Announcements & Project Buildups 2 08-31-13 06:41 AM
FS (USA,CA): aps tsr70 3.5 tubo back header full kit b line oil cooler zerosports crank pulley Robspec Engine/Drivetrain/Performance Parts For Sale 5 04-14-11 06:25 AM
The Oil Extreme Oil Change by Interior Flair! Interior Flair GD-Vendor Classified Ads 30 07-29-09 08:30 AM
FS: (OH) Process West Oil Cooler w/ Thermostat - SOLD loworbitSI Engine/Drivetrain/Performance Parts For Sale 4 01-25-09 09:12 AM
