aos systems - to splooge or not to splooge - Page 3 - Subaru Impreza WRX STI Forums: IWSTI.com
Go Back   STI Forums > > > aos systems - to splooge or not to splooge
Old 10-08-19, 10:02 AM   #21
mheyman
Feedback Score: 4 reviews
Fav Mod: Camber Camber Camber! Power! Wide ratio gearing! The rest is just support :)
Default Re: aos systems - to splooge or not to splooge
AOS should not require a tune - should it? but if your car doesn't require a tune otherwise that I'm not sure an AOS is of much benefit unless you are tracking it. The more you push the car, and the more power it makes, the more you need one, YMMV.
I can attest that the IAG Comp works really well. I can also attest that I would not install one one a stock DD. It's just too invasive. I am happy to have one in my car though. For cold weather I'd forgo most of the others altogether, though the KB might be a good option for warm climates and track use.
IMHO, to justify its' price, the S209 needs to perform at least as well as my moderately powered 05 built beater, and even that might not convince me to buy one cause my next STI isn't likely to be moderately powered.
I'm putting IAG back in here. Engine wise the car hase been trouble free for 56K. My STI is nearing the 60K minimum JJ led meto expect from a 2618 piston equipped block and it's still running strong.
mheyman is offline
Old 10-08-19, 10:40 AM   #22
killerbmotorsport
Feedback Score: 12 reviews
Car: Blue 05 WRX STi
Fav Mod: It's all good
killerbmotorsport is a glorious beacon of lightkillerbmotorsport is a glorious beacon of lightkillerbmotorsport is a glorious beacon of lightkillerbmotorsport is a glorious beacon of lightkillerbmotorsport is a glorious beacon of light
We have a cold climate kit. Same parts you find on a piston engine aviation crankcase system made for cold climate operation.
Our product performs as you'd expect from any of our products.
We do get very positive feedback on the installation. Without coolant lines the install takes half the time. So if you're having a shop install, the labor cost is considerably lower making the overall price more comparable to the mainstream products out there.
Another advantage we have is that the top can be opened in less than a minute to inspect the inside. This can be done at oil changes. It allows for a quick and easy wipe down of the internal surfaces and very easy method for checking and verifying proper function (clogged or kinked lines).
HOLY HEADER - Highly Advanced and Full of Awesomeness - Patent Pending
OEM Oil Pickup Failures vs. The Ultimate Oil Pickup
World's Best Performing Air Oil Separator
Brushed Delrin Shift knobs - Grab Our Knobs - It's Good Shift! CLICK HERE!
killerbmotorsport is offline
Likes 1 Dislikes 0
Old 10-08-19, 01:58 PM   #23
STINick19
Advanced Contributor Level 2
STINick19 will become famous soon enough
Originally Posted by Scargo View Post
Which ones can be used that do not affect a new car warranty?
None.
STINick19 is offline
Old 10-08-19, 02:09 PM   #24
killerbmotorsport
This is really going to be dealer dependent. Some dealers are enthusiast friendly and have the knowledge to know an AOS is not going to cause a rod bearing failure dealers that are likely to deny a-n-y-t-h-i-n-g because it is not OEM original are likely not going to warranty you anyway for not having ever oil change documented at their dealership. If they want to be difficult that is their choice. Legally, Magnuson-Moss act states that any dealer bares the burden of proof that an installed parts caused the failure. I would be hard pressed to think that any AOS out there that actually has engineering time into it could cause such a thing. Even a lot of the crappy ones shouldn't cause your engine to blow up.
Similar Threads
IAG AOS Review user1029 2.5 Liter/Litre Factory Motor 227 08-11-17 09:18 AM
IAG Billet AOS IAG Performance Vendor Announcements & Project Buildups 90 07-08-15 08:39 AM
Crawford Air/Oil Separator - Top 10 Questions To Be Answered CrawfordPerformance.com 2.5 Liter/Litre Factory Motor 252 08-31-12 10:26 AM
grimmspeed AOS vs crawford AOS - review monkiboy 2.5 Liter/Litre Factory Motor 24 03-13-12 06:36 PM
