Ok guys time for some killer engine deals. Dont miss out on the ATP GT30 Turbo Kits. These kits are red hot and are ready to tear up the street. Also in stokc are the Gruppe-S Engine Refresher kits. Perfect for thoes EJ engines with high miles. All items in stock ready to ship just in time for the holidays.
ATP GT30 Turbo Kits
ATP GT3076R Turbo Kit
Xtreme Eugene Killer System
-GT3076R/ or GT3071R Turbo
-Hydra EMS
-Perrin 3" Turbo Inlet Pipe
-Denso 860cc Injectors
-Walbro 255 lph Fuel Pump - w/ Setup Kit
$3999 Shipped to the door.
Pro Max System
-Cobb Accessport
$3199 Shipped to the door.
Street System
-Cobb Accessport
$2950 Shipped to the door.
ATP GT3076R/ or GT3071R Turbo
$1799 Shipped to the door.
IHI VF34 Turbo 400HP Package
The IHI VF-34 Turbo is found on the limited production Subaru v7 WRX STI-RA (GDB). This turbo is differentiated from the VF30 through its more advanced bearing design. The bearing design allows for much quicker turbo spool-up (depending on tuning, 300-500+ RPMs over the VF30), while retaining the power capabilities of the VF30. The VF34 is capable of 400 HP. This turbo is a direct bolt-on for all GC8, GDA, GDB EJ20 turbo engines.
IHI Turbo Package
- IHI VF34 Turbo
- STI 565cc Injectors,
- Walbro GS342 Fuel Pump w/ setup kit
IHI VF34 Turbo 400HP Package $1275.00 Shipped!!
VF34 Turbo $825.00 Shipped!!
MHI 18G Turbo 475HP Package
The new MHI TD05H 18G turbo for Subabru WRX. With 8cm2 turbine housing, also included are water lines and oil drain line. This high-powered upgrade is good for 475 HP to wheels and flows 600 cfm! 1yr warranty. This turbo is a direct bolt-on for all GC8, GDA, GDB EJ20 turbo engines.
MHI 18G Turbo
-MHI 18G Turbo
- PE 650 or 800 cc Injectors,
MHI 18G Turbo 475HP Package $1200.00 Shipped!!
MHI 18G Turbo $675.00 Shipped!!
Perrin GT30 550HP Turbo Combo
PERRIN Rotated Turbo kits include everything for your properly tuned WRX/STI. PERRIN kits are designed to bolt to factory exhaust manifolds, and to factory catback exhaust.
Simply add a front mount intercooler, injectors and fuel rails, ECU tuning, clutch, cat-back exhaust and you are ready to claw apart the surface of your local racetrack! All systems have a fully recirculated wastegate dump tube to prevent fire, noise and stench.
PERRIN Turbo kits are not for the faint of heart and it is best to speak to a PERRIN specialist before ordering.
Perrin GT30 Turbo Combo
-Perrin GT30 Turbo Kit
-PE 800 cc Injectors
-Perrin Fuel Rail
-Cobb Accesport
-Walbro GS342 Fuel Pump w/ setup kit
Perrin GT30 Turbo Combo $4100.00 Shipped!!
Engine Rebuild Kits
EJ20 Engine Combo
-Weisco (std) Pistons
-Weisco Piston Rings
-Helix Forged Rods
-Coated Race Bearings
$699 Shipped
EJ20 +020 Engine Combo
-Weisco (+020) Pistons
-Helix Forged Rods
$699 Shipped
EJ20 +040 Engine Combo
-Weisco (+040) Pistons
-Helix Forged Rods
$699 Shipped
EJ25 Engine Combo
-Helix Forged Rods
$699 Shipped
EJ25 +020 Engine Combo
-Helix Forged Rods
$699 Shipped
TGV Delete Combo
Gruppe-S TGV Deletes & Cobb Accessport
WRX/ STi/ Forster Xt/ Legacy GT/ Outback XT $700 Shipped
PM For Acessport Price
JDM STI Spec C TGV-Less Manifold
-JDM Spec C Red Manifold (no TGVs)
-Includes Gruppe-S Fuel Rail Adapter (required)
$449 Shipped
Okada Projects
Plasma Direct
The Plasma Direct is the ignition coil with a high power amplifier built in to it.
The Plasma Directs produce 4 times more spark energy than stock coils and also generate an ultra fast multi spark discharge of 10 sparks up to highest RPM.
The spark amperage is increased 100%, allowing the spark to reach many more molecules and therefore accelerate the ignition and combustion process. This is extremely important in forced induction applications but also improves the performance of normally aspirated engines.
The Plasma Direct will increase horsepower and torque throughout the entire rpm range. This upgrade will also reduce fuel consumption. Even the engines with a legendary smoothness will be further refined with the Plasma Direct upgrade. Our Plasma Directs are OBD II compliant and C.A.R.B. approved.
Installation is easy. Direct bolt-in to the engine, no splicing or cutting into stock wiring, simply replace the stock coils with our Plasma Direct Coils and ready to go!
Plasma Direct $655 Shipped Free Spark Plugs
Plasma Spark
The Plasma Spark is the Spark Plug Boot (Socket) specially designed and developed to work as a secondary amplifier.
It creates strong sparks in very short time (nano-seconds), creating a faster flame front and quicker light-off of the mixture kernel to complete combustion. Installing the Plasma Spark, you can feel immediate torque up from low RPM and get more horsepower to the high RMP range!
Also installation is easy, direct bolt-in to the engine, no splicing or cutting into stock wiring. Simply replace the stock boots with our Plasma Spark Boots and ready to go!
Plasma Spark $285 Shipped Free Spark Plugs
AEM Alcohol Injection
AEM’s Water / Alcohol Kit reduces air inlet temperatures, which allows you to increase boost pressure and advance timing without having to run higher-octane fuel. It’s like getting to run 100+ octane gas for the price of Premium!
AEM Alcohol Injection $375 Shipped
CLICK HERE FOR PERFORMANCE SPECIALS -- UPDATED DAILY
Call in to order!
We accept Visa, Mastercard, and paypal.
GRUPPE-S, please specify vehicle, part, and your info.
Thanks,
Gruppe-S Sales
GRUPPE-S
20521 Teresita Way
Lake Forest, CA 92630
949-457-1234 x 2
ATP GT30 Turbo Kits
-Hydra EMS
Pro Max System
-Cobb Accessport
Street System
-Cobb Accessport
IHI Turbo Package
- IHI VF34 Turbo
MHI 18G Turbo
-MHI 18G Turbo
-Perrin Fuel Rail
-Cobb Accesport
Engine Rebuild Kits
EJ20 Engine Combo
-Helix Forged Rods
$699 Shipped
-Helix Forged Rods
$699 Shipped
-Helix Forged Rods
$699 Shipped
EJ25 Engine Combo
-Helix Forged Rods
$699 Shipped
-Helix Forged Rods
$699 Shipped
TGV Delete Combo
$449 Shipped
Okada Projects
Plasma Direct
Plasma Spark
Call in to order!
Thanks,
Gruppe-S Sales
GRUPPE-S
20521 Teresita Way
949-457-1234 x 2
