Go Back   IWSTI.com: Subaru STI Forums > STi Marketplace > Vendor Classifieds > Archived Vendor Classified Threads by Vendor > WeSellCarParts.com
Old 01-23-2008, 06:19 PM   #1
Trader Rating: (19)
Send a message via AIM to WeSellCarParts
Default APS Stock and Price
APS Stock and price as of 1/23/08
Items CURRENTLY in Stock with Price shipped in Continental U.S.!
Tube headers equal length, polished stainless steel to suit US Spec STI
(up pipe required) APS SSTI-EMK/02 - 750 Shipped
Stock position turbine inlet (up pipe) 321 Stainless Steel cat delete
with 321 SS flex section - to suit APS headers APS SSTI-TIP/07 - $260 Shipped
Billet Fuel Rails All pre-assembled teflon/ss lines, steel fittings.
Side feed injectors APS STI-FRP/01 - $450 Shipped
Heat Shields to suit APS Headers APS STI-HSK/01 - $205 Shipped
Conversion Kit- Permits simple installation of any APS FMIC to 06/07
models APS WRX-FMI/CK - $210 Shipped ($195 Shipped with any FMIC)
DR725 Front Mount Intercooler Massive bar and plate core 4.5" Thick.
Rated to 725+ HP Specify BLACK************ finish APS WRX-FMI/R4B - $1495 Shipped
Rated to 725+ HP Specify SILVER************ finish APS WRX-FMI/R4S - $1495 Shipped
DR525 Front Mount Intercooler. Serious bar and plate core. 3.25" thick.
Rated to 525HP Specify BLACK************* finish APS WRX-FMI/R6B - $1295 Shipped
Rated to 525HP Specify SILVER************* finish APS WRX-FMI/R6S - $1295 Shipped
APS 65MM Cold Air Intake for Subaru APS WRX-HFA/01 - $295 Shipped
Compressor Inlet Duct -3" ID hose/tube construction APS WRX-CID/01 - $265 Shipped
Dual Vent Blow Off Valve, Direct bolt on to any top mount intercooler
APS 995-047-000 - $250 Shipped
APS 70MM Cold Air Intake for Subaru APS WRX-HFA/02 - $335 Shipped
Turbo back exhaust system, 3" polished 304 stainless steel tube,
flanges, TIG welded - single 4" tip - 95 DB APS WRX-HOE/R1 - $1125 Shipped
Dual vent blow off valve direct bolt on. Protect turbocharger at high
boost levels. Improves engine response on gear change APS 590-047-000 - $250 Shipped
Turbo back exhaust system, 3.5" polished 304 stainless steel tube,
flanges, TIG welded - single 4" tip - 100 DB APS WRX-HOE/R5 - $1350 Shipped
Top Mount Intercooler. Bolt on bar and plate replacement for stock unit.
Rated to 375hp Suites all driven and thottle by wire vechicles. APS
WRX-TMI/06 - $749 Shipped
TSR70 Turbo System- split scroll turbocharger, split scroll up-pipe,
tial wastegate 3.5" turbine outlet pipe to any APS exhaust, all
hoses/fittings included. 700hp (flywheel) APS WRX-RMT/03 - $3495 Shipped
Tumbler Valve Delete provides provision for auxillary injector mouting.
Top feed injector -No tuning re. NON US SPEC APS WRX-TDI/01 - $650 Shipped
Billet 5/8" ID Rails regulator mouting block. All pre-assembled
teflon/ss lines, steel fittings. -top feed injectors APS WRX-FRP/03 - $455 Shipped
3" flanged act converter, high flow, high temperature - suits all 3" APS
systems APS 995-019-200 - $360 Shipped
High Flow Cold Air Intake, Rotated Mount Turbocharger NC Machined.
65/80mm ID APS WRX-HFA/R9 - $499 Shipped
Thanks!
WeSellCarParts is offline   Reply With Quote
