Old 08-15-2007, 10:30 PM   #16
Car: 06 STi
Fav Mod: boost creep!!!!!
IWSTI Addict since: Dec 2005
Default Re: Where do you buy your meth at
Originally Posted by jasv11
I'm pretty sure its only 15% methanol/alcohol
Edit: Supertech washer fluid is 40% methanol, HEET (yellow bottle) contains 98% meth
sti-06 is offline   Reply With Quote
Old 08-15-2007, 10:31 PM   #17
Car: 05' CGM on silver
Fav Mod: Ed's tune!
IWSTI Addict since: Sep 2004
Send a message via AIM to USAF_STi
HEET is methanol that is very accessible.
USAF_STi is offline   Reply With Quote
Old 08-15-2007, 10:33 PM   #18
Car: No car.
Fav Mod: No car note.
IWSTI Addict since: Nov 2005
Send a message via AIM to VtecSTI Send a message via MSN to VtecSTI Send a message via Yahoo to VtecSTI
Most speed shops, and propane stores sell it. I'm always traveling so it's sometimes hard to find. If i run out, i just flash to my pump map
VtecSTI is offline   Reply With Quote
Old 08-16-2007, 05:02 AM   #19
Non-Reformed Meth Addict
Car: '06 WRB
IWSTI Addict since: Feb 2006
Originally Posted by NSFW
RC engine fuel is for two-stroke engines (or four-strokes that lubricate with fuel, similar to two-strokes) so there's lubricants in it. But the guy above buys it direct from a producer in his area, so he may be getting the "raw material" they blend with lube to make the stuff they sell.
DING DING DING! Yeah I buy the raw stuff. They have a fully automated system that blends the fuel from the raw ingredients. The get all their ingredients in huge bulk shipments. Don't ask them to show you how they blend the fuel though. They won't show you.
Old 08-16-2007, 06:38 AM   #20
Car: cgm 05 sti
Fav Mod: cf hood w/ painted sides
IWSTI Addict since: Mar 2004
I want to know if I add either methonal or washer fluid to my sti stock intercooler spray bottle in the trunk, will this cool down the top mount better than distilled water only.. Can any additive hurt my car either mechanically or appearance wise// thanks phil
philbay40 is offline   Reply With Quote
Old 08-16-2007, 06:47 AM   #21
Car: aspen 2005 wingless
IWSTI Addict since: Sep 2006
I'm sure if you sprayed enough methanol directly onto your intercooler, over about 5 years, you MIGHT see some effects on the aluminum. the effect over water would be negligible. Alcohol evaporates at a lower temperature, so meth wouldn't sit on the TMIC as long as water would. What works better I do not know, but it's probably not worth the hassle. Use the meth injection in your car, the evaporative cooling properties of water combined with the oxygen molecule of the meth serving as ADI will be better than any form of spray onto your top mount.
I buy methanol from the race gas shop, $2.00 per gallon. Distilled water from Walmart for 0.79. Snow's boost juice is for chumps...
Old 08-16-2007, 08:03 AM   #22
HowTo Contributor
Car: 06 STi
Fav Mod: 10.91 at 127.08
IWSTI Addict since: Mar 2006
Well my sources were wrong then
I guess they wouldnt be able to sell me meth if I used washer fluid
jasv11 is offline   Reply With Quote
Old 08-16-2007, 09:36 AM   #23
Car: white 07 limited STI
Fav Mod: Alky Injection
IWSTI Addict since: Nov 2004
Where do I find HEET? Is that a windshield wiper fluid? HEET sounds like it might be best for my needs. Does anyone use HEET in thier meth injection system?
quikbluesti is offline   Reply With Quote
Old 08-16-2007, 11:17 AM   #24
Fav Mod: Ed's tune!
HEET will be in any autozone, walmart, or whatever. I for get what exactly it is for, maybe as a de-icer or something.
Old 08-16-2007, 12:39 PM   #25
I've cleaned out my local autozone 2x
It seems to work well.
Tgui is offline   Reply With Quote
Old 08-16-2007, 12:50 PM   #26
Car: 06 STi WRB
Fav Mod: Spec C Roof Vent:Cobra Seats:Custom Cage
IWSTI Addict since: Aug 2006
Your comment on Propane stores is right on. They have methonal to purge newly vaccumed tanks. Also aids in melting frozen valves. They always have barrles of the stuff. My company has about 3 at each facility
Tbagger is offline   Reply With Quote
Old 08-16-2007, 01:49 PM   #27
Car: Evolution X GSR
Fav Mod: Stock for now!
IWSTI Addict since: Oct 2004
Send a message via AIM to SNE2040
how much does HEET go for?
SNE2040 is offline   Reply With Quote
Old 08-16-2007, 04:18 PM   #28
Fav Mod: My Tune
IWSTI Addict since: Mar 2007
HEET is sold at every gas station and department store here in Alaska. Maybe not so "down south"? I am running HEET for about 8000 miles now, 80/20 mix with distilled water, at 27psi boost. Works like a dream. HEET is 99% methanol by content, the rest is engine coolant, such small amounts will not hurt your engine, but will show up on the oil analysis if you have it done. AKWRX from NASIOC is at 75,000 miles now, no problems with HEET whatsoever.
13rus is offline   Reply With Quote
Old 08-16-2007, 04:21 PM   #29
Fav Mod: My Tune
$1.25 - $1.70 per bottle here. Use yellow bottles.
Old 08-16-2007, 08:24 PM   #30
Car: 04 Sti
IWSTI Addict since: Aug 2004
I buy it locally at a gas station for $2.25 gallon+$1 gallon for distilled water. So $1.65 a gallon of 50/50. Beats $25 a gallon
Irishman is offline   Reply With Quote
