Old 07-31-2007, 02:53 PM   #1
Car: 04 Subaru WRX STI
Fav Mod: METHHH
Send a message via AIM to xourheartsdesir
Default Meth Not Pumping?
hey guys i have the snow performance meth kit installed from xx tuning and this has been the second time this has happened. ill notice my car is slower so i look at my meth line and theres no juice in it in the engine bay...nor the trunk where the pump is. i dont know what is wrong last time this happened i filled it to the top and it ran fine again. the nozzle is tapped in the bottom of the I/C tank so its not like its not getting meth. whats the problem??? i checked the grounds they are good....the green LED comes on at 8 pounds like usual...i dont understand. MAF sensor? clogged? ughhh and i called xx and i cant get in till next saturday...why cant u bump me up because this isnt a install its a problem that needs to be fixed. dont understand that one...not like u wont fix it in 20 minutes anyway. any ideas or feedback on this let me kno...i hate having to go slow
xourheartsdesir is offline   Reply With Quote
Old 07-31-2007, 02:57 PM   #2
nulla poena sine lege
Default Re: Meth Not Pumping?
do you have the snow boost controller (failsafe) installed? Sounds like an install issue - is the pump mounted correctly?
QuickSilverSTi is offline   Reply With Quote
Old 07-31-2007, 03:13 PM   #3
Fav Mod: METHHH
yea should be xx did it haha. what happens if my car is protuned for meth and it doesnt flow? will it still run mad boost and everything or will it not detect meth and not do anything
Old 07-31-2007, 03:25 PM   #4
Without knowing your failsafe system, and whether or not it is working, no one here can say. Stay the hell out of boost until you figure this out.
Old 07-31-2007, 04:26 PM   #5
It will toast your motor if you don't have a failsafe such as the Snow SafeInjection. It is similar to getting a tune on race gas and then trying to run pump if you don't have a failsafe. Snow has not released the new SafeInjection and stopped producing the old SafeInjection which is why I've been waiting months to install my meth...
