View Poll Results: Have you ever encountered problems with your meth injection system?
No - I have never had any issues with it 29 76.32%
Yes - I have had some issues with it 8 21.05%
Yes - It destroyed my engine 1 2.63%
Voters: 38. You may not vote on this poll
Old 05-16-2007, 09:55 AM   #1
high and mighty
Car: 2004 STi
Default Data Collection: Meth Injection Systems - DO YOU HAVE ONE? Answer this poll!
this is a public poll (meaning your choices will be seen by all members of IWSTi).
ONLY ANSWER THIS POLL IF YOU CURRENTLY HAVE OR HAD A METH INJECTION SYSTEM.
this poll/thread's only concern is if you have a meth injection system in your car, and, if you have encountered any issues with your car due to your meth system.
  1. if you answered the poll with "No - I have never had any issues with it" - please provide a post of which system (and version) you have.<br>
  2. if you answered the poll with "Yes - I have had some issues with it" - please provide a post explaining which issue you encountered, and which system (and version) you had that issue with.<br>
  3. if you answered the poll with "Yes - It destroyed my engine" - please provide a post explaining what happened, and which system (and version) you had.
*this thread is going to be closely moderated, and any posts that try to take this thread off topic - (away from data collection and reasons for a specific vote) - will be deleted without warning. re-creating deleted posts will be "rewarded heavily" with points.
*all necessary updates by myself (or any other moderator) to this thread or poll will be posted here, in the first post.
Old 05-16-2007, 10:13 AM   #2
Car: 05 STi OBP
Fav Mod: All of them
Default Re: Data Collection: Meth Injection Systems - DO YOU HAVE ONE? Answer this poll!
I have the Perrin meth kit, very nice unit. Had some initial issues with the control board causing a false low flow signal (which triggered a failsafe and cut boost). A few others had the same issue, just to note that my unit was one of the first ones sold, I have been told that this has been resolved.
Richard at Aquamist and Jeff at Perrin have been AWESOME in fixing the issue and now its working great.
Black-STi is offline   Reply With Quote
Old 05-16-2007, 10:15 AM   #3
high and mighty
Car: 2004 STi
no problems thus far.
i have run the SMC Kit - ver. 2.0 for a year.
Old 05-16-2007, 10:25 AM   #4
I've been using it for 13K miles, on a Cobb "Tuner" Stage 2 block, GT30R, 400 whp. Zero issues, all UOA's nominal.
Details:
Aquamist with boost-cut failsafe (never fired yet)
50-50 H20 and Meth
10 psi injection start point
Old 05-16-2007, 12:15 PM   #5
Have the Perrin kit. One of the first units so had some issues initially with the control board and the overly sensitve low flow indication. Also had a failed flow meter. The board was updated and flow meter replaced. No problems since. Great support from Perrin and Aquamist.
Bus Driver is offline   Reply With Quote
Old 05-16-2007, 12:46 PM   #6
Car: 05' CGM/Silver STI
Fav Mod: UR 35R and Hydra tune by Scott Siegel :)
Send a message via AIM to JDM-STI Send a message via MSN to JDM-STI
I currently run the SMC kit. I started out with the under the hood kit. Only problems that I had was boil off from high under the hood temps. I then got the JDM Spec tank and had Steve at SMC set the pump up for that. Absolutley flawless since. I have the version 2.0 control box. Been running 100% meth for over a year with no issues at all. If I ever change, it will be to the Hydramist system. Only because I am currently getting tuned with my new Hydra and it will control the Hydramist meth kit.
JDM-STI is online now   Reply With Quote
Old 05-16-2007, 12:51 PM   #7
all bOOst
Car: pwn3d by bambi
Fav Mod: utec sd racegas tune
Send a message via AIM to forgedSTi
i have an aquamist 2d. i was spraying (50/50) when my stock block with 35r popped on me while winding out 3rd gear. afaik, the system had no issues and worked normally. did it contribute to my motor letting go? i have no idea, thus, i'm not sure how to answer your poll.
forgedSTi is offline   Reply With Quote
Old 05-16-2007, 01:18 PM   #8
520
pwns n00bs
Car: 03 EVO
Fav Mod: stock :(
Send a message via AIM to 520
Does this count if i run Denatured Alky?
Old 05-16-2007, 01:19 PM   #9
Car: Slow 05 STi
Fav Mod: Loping Idle
SMC Kit
Ran 100% meth, loved it, made great power, washed out a cylinder wall on a freak inlet rip that only let air out and not in. Ran for 20k and would have gone for more but the going says, race it - break it - fix it better - go faster
New Plan - SMC Kit
10% meth - 90% h2o
Take adavntage of the cooling effects of mostly water while getting a minute amount of octane out of the car.
ARFab secret motor
Lots of tuning.
Old 05-16-2007, 01:22 PM   #10
high and mighty
Car: 2004 STi
in my opinion, it sounds like too much power was the cause.
Old 05-16-2007, 01:51 PM   #11
Fav Mod: <---- Agile Tuned STi
SMC kit for about 6 months
WOR440 is offline   Reply With Quote
Old 05-16-2007, 02:38 PM   #12
Fav Mod: when it's not blown up
I own an SMC kit. The only problem I ever had with it, was running out of meth and not noticing the flashing warning light.
My motor did blow up, but I did things far worse than running it out of meth...
Old 05-16-2007, 03:39 PM   #13
Originally Posted by jays05
...My motor did blow up, but I did things far worse than running it out of meth...
Boy, I dunno...doesn't sound like it to me.
Old 05-16-2007, 04:01 PM   #14
Fav Mod: CP35r 440whp
SMC v2.0
50/50 water meth start 12psi full 22psi
ZERO problems
I don't have a failsafe, but I will very very soon....
meth injection is arguably, one of my favorite mods (next to my fmic)
Old 05-16-2007, 04:11 PM   #15
Car: x2 05 WRX STi's
Coolingmist, cgm STi, starts at 10psi and full flow at 20psi
wrb STi, starts at 5 psi and full flow at 16psi
both use 50/50 mix meth... PDX tuned.
Sinister redlines is offline   Reply With Quote
