View Poll Results: Have you ever encountered problems with your meth injection system?
No - I have never had any issues with it 29 76.32%
Yes - I have had some issues with it 8 21.05%
Yes - It destroyed my engine 1 2.63%
Voters: 38. You may not vote on this poll
Old 05-16-2007, 04:31 PM   #16
Fav Mod: BOV and MBC
Default Re: Data Collection: Meth Injection Systems - DO YOU HAVE ONE? Answer this poll!
SMC kit, problems with the spray light being constantly on, ended up being a grounding issue, also the windsheild washer spray stopped working, also Jason you be da GB.
Old 05-16-2007, 05:33 PM   #17
520
STi > EVO... Wait what???
Car: 03 EVO
Fav Mod: stock :(
Send a message via AIM to 520
Originally Posted by 520hpSTi
Does this count if i run Denatured Alky?
Since no one answered i assume it does count.
I use 100% denatured alky with the SMC kit and have had no problems. Just make sure to fill it when i need and use the oli to lube the pump / filter.
520 is online now   Reply With Quote
Old 05-16-2007, 07:23 PM   #18
Fav Mod: Pro-Tune
Trader Rating: (16)
CoolingMist stage III kit w/clogged nozzle detector/stainless lines/float valve/1gal trunk tank & pump.
No problems with the kit, but I am waiting on my car to get out of the shop, after shattered ring lands pWn3d me. 50/50 mix.
Question is: did the meth contribute? The answer may never be known.
CB
Old 05-22-2007, 04:58 AM   #19
Car: 04 Aspen White STi
Fav Mod: exhaust powered intake
SMC kit 60/40 meth/water had it for over 6months now and no promblems, just test it each time before i drive. Usually between 23-25psi on stock block with a GT35R turbo kit
B4RSTiwsnc is offline   Reply With Quote
Old 05-22-2007, 03:56 PM   #20
Fav Mod: My Tune
I have an '06 STI SMC alcohol injection kit (trunk-mount) for 5000 miles (4 months) now. Never a single issue. Allows me to safely run 24-26 pounds of boost on stock block. Of course all supporting mods were done for safety and reliability. Performance is closely monitored and datalogged with UTEC.
Using yellow bottles of HEET(99% methanol) for alcohol source ($1.39 a bottle). Usually run about 70% Alcohol and 30% Water, sometimes its 80/20, 90/10 and sometimes just straight Alcohol when I'm too lazy to buy distilled water. I think I noticed that the 80/20 alcohol/water mix works best to prevent knock. Also ran Denatured Alcohol(80/20 water mix) for a while, no problems. It will also run perfect on rubbing alcohol.
AKWRX from Nasioc is running an SMC under-hood kit on his 400whp 2002 WRX for 75,000 miles now without a single issue. He is running 80/20 or 90/10 mixes as he feels appropriate.
13rus is offline   Reply With Quote
Old 05-22-2007, 04:02 PM   #21
Car: MY06
Fav Mod: Valentine-1
Running a coolingmist system 50/50 meth/water. No problems so far, its been on about a year. I have a 20g turbo and run 25-26 psi no problems. Been watching the oil consumption close, good there too. Its been good so far.
superhero06 is offline   Reply With Quote
Old 05-22-2007, 04:07 PM   #22
Muller Chevrolet
Fav Mod: fp green
smc kit 75/25 mix for almost a year.
VSGTS14 is online now   Reply With Quote
Old 04-23-2008, 06:04 AM   #23
Car: 04 Sti Wrb on Silver
Aem Kit, stock turbo and intercooler running 50/50 mix and no problems at all.
Old 05-09-2008, 03:44 PM   #24
Car: 04 WRB/G STi
Fav Mod: Sz49 + Meth
SMC 100% meth...no problems ever.
Boostpimp is offline   Reply With Quote
