Old 03-21-2007, 07:20 PM   #46
Car: 08 CBR1000RR
Fav Mod: None
IWSTI Addict since: Jun 2004
Even if you monitor it with everything under the sun, it only takes a few knock counts to blow your motor. At the rate of speed in which a motor is rotating, you most likely would not catch in time to save your motor. 22 psi is most likely to much for pump, but it all depends on the octane of gas you are running. There are some injection systems out there that offer safeguards. It might be worth looking into one of those systems if you are really wanting to do injection, but to me it still isn't worth it. I can also tell you from experience that the UTEC my retard timing if knock is detected, but it is very slow at reacting to it. I had the UTEC on my 03 WRX and I remember it retarding timing a few times, but it wasn't fast enough for me to not notice the rattle of beebees in a can that was coming from my motor knocking. This was when the first UTEC came out so I'm sure its improved, but most tuners prefer an ecu reflash over a piggyback anyday of the week.
Old 03-21-2007, 07:50 PM   #47
Car: 04 Aspen White STi
Fav Mod: exhaust powered intake
IWSTI Addict since: Jul 2006
93 octane
B4RSTiwsnc is offline   Reply With Quote
Old 03-21-2007, 07:56 PM   #48
Car: 05 sti
Fav Mod: All of them
IWSTI Addict since: Feb 2007
I thought I would add this...
93 octane...
22 to 24 psi...
Meth injection...
over 400whp...
At almost 36,000 on stock engine...
Daily driver...
Meth doesn't kill motors.... Tunes do....
shvrdavid is offline   Reply With Quote
Old 03-21-2007, 07:59 PM   #49
520
STi > EVO... Wait what???
Car: 03 EVO
Fav Mod: stock :(
IWSTI Addict since: Oct 2005
Send a message via AIM to 520
^ Werd!
Old 03-21-2007, 08:10 PM   #50
Car: 06 STI - SGM
Fav Mod: HPDE
IWSTI Addict since: Dec 2004
Originally Posted by RacerXS
It's not the Meth, or any particular bolt on that kills engines for the most part......it's THE TUNE!
Time & time again I see a story about how this or that "killed my motor", METH does not destroy your motor when tuned properly. In fact it can save you from detonation, which is probably the #1 killer of our motors.
NinjaBoy is a perfect example of a tune destroying a motor.
DON'T SKIMP on the tune! Make sure it's right on. If that means going back 2,3,4 times, then do it. Get Street Tuner, if nothing else to become familiar with how the ECU works and why.
If your going to create an STi that produces over 400WHP, you better be very aware of how the car is running. Get all the proper gauges, keep your eye on everything. But most of all, listen & feel what the car is doing ALL THE TIME. If it does not feel right....do something about it! Or your going to have a broken ring land, a hole in your piston, or a broken rod.
I can tell if my car is running lean without looking at the AFR gauge.
Check your oil every few days, look at the oil catch cans & see whats inside, etc, etc..
You can't just drive a 400WHP STi and not be "in touch" with what the car is doing.
Yep...right on, right on.
Meth is not an issue, as it evaporates so fast and is burned so fast that there is NO corrosion to engine parts from it. The problem comes from when there is TOO MUCH sprayed and/or the tune is not right.
It's been used since WWII. It's not the problem.
Be good,
TomK
ace996 is offline   Reply With Quote
Old 03-21-2007, 09:28 PM   #51
shvrdavid, that helps my worries! I have 46k now
Old 03-22-2007, 08:08 AM   #52
Car: Silver 08 STI(stock)
IWSTI Addict since: Dec 2005
Send a message via AIM to sutter2k
Be good,
TomK
What happens if you have a higher HP setup (e.g. your alky nozzle is bigger)
and you hit the test button at a traffic light. But revs are up slightly.
Is it burned up fast then?
sutter2k is offline   Reply With Quote
Old 03-22-2007, 08:11 AM   #53
IWSTI Addict since: Feb 2006
I think mine was either too much power for the stock rods, bad gas, water in the tank or the vacum hose popped off. We suspect all of them because of what we've seen.
awdmonsta is offline   Reply With Quote
Old 03-22-2007, 08:11 AM   #54
93 octane...
22 to 24 psi...
Meth injection...
over 400whp...
Daily driver...
what turbo are you running?
Old 03-22-2007, 08:53 AM   #55
Moderator
Car: 05 Ram 3500 CTD
Fav Mod: Majin
IWSTI Addict since: Apr 2006
He's running the VF39 stocker...
...NOOT!
Old 03-22-2007, 09:37 AM   #56
DOMINATOR
Fav Mod: Strut Clunk
IWSTI Addict since: May 2005
...NOOT!
He is running the stock turbo pause not.
Muffnbluff is online now   Reply With Quote
Old 03-22-2007, 09:54 AM   #57
Moderator
Fav Mod: Majin
He is NOT running the stock turbo.
Old 03-22-2007, 11:52 AM   #58
Car: Crystal Grey 05 STI
Fav Mod: Turbo
IWSTI Addict since: Jan 2005
I've got 36,000 miles on my 2005 STI.
SZ49 with methanol injection at 22-23 psi making about 410 whp and 440 wtq.
No problems yet. I've had my car modded for 20,000 miles. No increased oil consumption. No leaking at all. Runs smooth and crisp. Maybe I won the mod your car and it runs well lottery. Of course, my luck and the car will suffer some catastrophic failure soon. I continue to make offerings to the subaru gods for their favor and my gratitude.
SR2017 is offline   Reply With Quote
Old 03-22-2007, 11:55 AM   #59
awesome!
Old 03-22-2007, 03:12 PM   #60
Car: 05 sti
Modified APS DR55... They start life as a GT30r .63...
