| Professional STI Racer Car: 06 subaru wrx sti Fav Mod: royal purple Location: orange, CA Posts: 732
IWSTI Addict since: Jul 2006 Trader Rating: (0) | so how much whp wtq am i looking at with a tuned methanol/H2O kit. This ad is not endorsed by this member. Please register or login to hide this ad. |
| | #2 |
| Moderator | There are too many variables for anyone to accurately answer that question, but figure somewhere between 300-350 whp/tq depending on how aggressive the tune, how much meth, your turbo, the dyno, the tuner, etc etc... |
| | #3 |
| The Next Petter Solberg Car: 2005 STI Fav Mod: Methanol Location: Boston area Posts: 926
IWSTI Addict since: Feb 2005 Trader Rating: (5) | 2005 sti here catless tbe MRT intake Perrin EBCS 1 step colder plugs 50/50 meth XX tuning in CT 307 whp 372 ft /lbs Stock IC, fuel pump, injectors, turbo ![]() Boost still falls off up top, limiting my HP, but as you can see , it is a torque monster down low. Roughly equivalent to 450 ft/lbs at the crank, enough to kill my stock clutch. Coolingmist kit. That should cover it, I LOVE it. Use it daily, run 21-22 psi peak (tapers like a *****) Used 10 gallons of 50/50 in 1 year. |
| | #6 |
| I Has a Turbo Timer
Car: 2005 Subaru WRX STi Fav Mod: Every single one! Location: NJ Posts: 10,075
IWSTI Addict since: Jun 2005 Trader Rating: (29) | Heres mine (Protuned by Doug from TopSpeed at XX-Tuning, CT): Baseline Run: ![]() Protune Pump (93 Octane): ![]() Meth Tune on Pump (93 Octane): ![]() AFR & PSI on Meth Tune on Pump (93 Octane): ![]() Mods List at the time it was tuned: Invidia V2 Catless DP Wrapped and sprayed APS Turbo Inlet APS CAI (65mm) Invidia G200 Catback Perrin Crank Pulley SMC Meth Injection (50/50 Meth/Distilled Water) M10 Spray Nozzle NGK 1 Step Colder Spark Plugs Walbro Fuel Pump |
| | #7 | |
| Silver Member Car: 07 Subaru STi Fav Mod: Coilovers/Tune Location: NY Posts: 1,231
IWSTI Addict since: Nov 2006 Trader Rating: (0) | Quote:
| | #8 |
| I Has a Turbo Timer
IWSTI Addict since: Jun 2005 Trader Rating: (29) | Sorry, all these pulls were in 5th gear. So 4th gear numbers are about 20whp/20wtq more. My Protune with 50/50 Meth is: 317whp/421wtq in 5th gear on DynoPacks. |
| | #9 | |
IWSTI Addict since: Feb 2005 Trader Rating: (5) | Quote:
Same car, similar setup, same dyno, different tuner, you got 10 more HP and 50 moe ft/lbs?!!?!?!? | |
| | #10 |
| I Has a Turbo Timer
IWSTI Addict since: Jun 2005 Trader Rating: (29) | Yup....she is a beast...now she is just meh alright fast...can't wait for my turbo setup to get in there , then I will really be liking it!I know the VF-39 is blah on the top end, thats what I want more of...off the line....I can rip the tires loose (Winter Tires) all throughout 1st gear, and still be loosing traction while going into 2nd. |
| | #11 |
| I Has a Turbo Timer
IWSTI Addict since: Jun 2005 Trader Rating: (29) | BTW, almost 8,000 miles of driving with this setup after the tune, 2 circuit events, and half a dozen of 1/4 runs.....stock clutch went in 5th and 6th gear . I advise if you go upgraded clutch, get the ACT Street Performance Clutch and the ACT StreetLite Flywheel...def worth it, no problems and I have the Perrin Crank Pulley and the ACPT Carbon Fiber 1 Piece Driveshaft.We also install clutches , you wouldn't believe how much me and Kiwi Ian charge, just incase you ever need one put in. |
| | #12 |
IWSTI Addict since: Jul 2006 Trader Rating: (0) | oh man its really worth it. damn those numbers are incredible. right now all i have is typhoon, catless TBE, and cobb stage II. i will buy and supporting mods for the meth kit before i tune. that 400+ wtq looks very sexy to me. cant wait. hope i net the same results. thanx for the post guys. |
| | #13 |
| I Has a Turbo Timer
IWSTI Addict since: Jun 2005 Trader Rating: (29) | No problem.....btw, my friend had some problems with his Typhoon, in the summer in traffic it just sucked up all the hot air in the engine bay.....maybe you should get the APS 70mm CAI for the tune.....those are great, but only if your tuned for them. |
| | #15 |
| Silver Member
Car: 05 Subaru WRX STi Fav Mod: DB 20G, Diamond Black BBS RE's, S2K retrofit Location: NY Posts: 4,632
IWSTI Addict since: Jul 2004 Trader Rating: (7) | Chris' setup is beastly, gotta love his torque curve. This ad is not endorsed by this member. Please register or login to hide this ad. |
| Thread Tools | |
