Old 11-04-2006, 02:39 PM   #16
Fav Mod: Soon to be FP RED with Axis Stage 3 Block
IWSTI Addict since: Oct 2004
So would you reccomend that I buy it directley from SNOW, because I live in colorado. The reason I am debating this is because I can save 200 dollars if I buy it from the company that wants to sponsor my car.
WRBSTI is offline   Reply With Quote
Old 11-04-2006, 02:41 PM   #17
Car: silver 05 sti
Fav Mod: My SIRIUS radio...listening to Howard 100!!!!
IWSTI Addict since: Nov 2005
Send a message via AIM to raginbull74
Ive havent heard anything bad about any of the companies so far (coolingmist/snow/smc) any one of them tuned correctly will get you alot more power...its my next upgrade for sure!
raginbull74 is offline   Reply With Quote
Old 11-04-2006, 03:02 PM   #18
Muller Chevrolet
Fav Mod: a new 09 STi
the only down to smc is their kit sits in the engine bay...i want to relocate my tank.
Old 11-05-2006, 09:41 AM   #19
Can people post pics of their meth setup. Also, who here is using the Snow Performance meth kit. Thanks.
Old 11-05-2006, 10:35 AM   #20
IWSTI Addict since: Jul 2004
I'm interested in more informatioj on these snow kits.
JJ18Sniper is online now   Reply With Quote
Old 11-06-2006, 01:53 PM   #21
So, for the people running the snow kit, where did you mount everything. Thanks.
Old 11-06-2006, 03:00 PM   #22
Car: 95 GSX
IWSTI Addict since: Mar 2004
I'd get it the cheapest place. Snow will have to charge you tax.
As for mounting, I'm using the small 2 quart container in the back trunk on the passenger side. Eventually I will be using the STi tank. I'd really like to purchase the spec C tank but thats $200. The pump is mounted next the spare tire with the tube inlets facing up. It screws to the flat panel in the spare tire compartment. The tube runs along the passenger side. I have the fail safe and main controller mounted on the passenger fender. I zip tied the two together and only had to drill 4 holes in the fender. The system runs off a relay with a switch inside. Easy to do just time consuming. Be sure to get enough tubing. The NitroBooster stuff really works too!
rodent is offline   Reply With Quote
Old 11-06-2006, 03:13 PM   #23
Car: 89 GT-R32
Fav Mod: no brake fade
IWSTI Addict since: Aug 2005
Send a message via AIM to BrewPubeaver Send a message via MSN to BrewPubeaver Send a message via Yahoo to BrewPubeaver
Cool
this isnt the snow kit, but you can get the concept.
Aquamist WI 2d complete kit, with the race pump and high-speed valve
Aquamist DDS3 blue bar water injection monitoring system.
race pump is down there... this is where the hispeed vave goes
used the stock intercooler sprayer for the tank, you have to wire in the level censor, so you know when it is getting low.
hi speed valve installed
lots of wireing to go to the Utec
DDS3, it is a flow meter, lets you know how much is in the tank, on/off switch, waning light, and it has more fetures but i cant remember what they are.
BrewPubeaver is offline   Reply With Quote
Old 11-06-2006, 03:15 PM   #24
Hey Rodent, I see that yout are located in Colorado. I just installed an FP 20g and had it tuned by adam at Revolutions. He did an amazing job and I am very happy. How do you like the meth. ALso, how many miles do you get to the 2l tank of meth. Thanks.
Old 11-06-2006, 04:06 PM   #25
Car: CGM 05 STI
IWSTI Addict since: Jan 2005
I have the Snow Performance resevoir mounted in my trunk on the rear drivers side. Pump is mounted on the trunk floor also on the driver's side. Doesn't seem to get in the way much.
darkcrystal05 is offline   Reply With Quote
Old 11-06-2006, 04:55 PM   #26
Did Adam from Revoltions install ti for you, or did you do it yourself. Thanks.
Old 11-06-2006, 05:17 PM   #27
Car: 95 GSX
I'm liking it. 24 psi of boost with injection is nice. Adam tried to get more out of my FP Red but it wasn't happening with my 7cm housing. May go 8cm soon. As for mileage, just depends on how much I get on it. Anything past 7psi and it will activate.
For some reason my fail safe is triggering mounted on the side. If I mount it flat, it works fine so I may do a bracket and rotate it so its flat. This is the 2nd failsafe I got from Snow and according to Greg, it shouldn't matter. I have to give Adam props for my tune. He spent the whole day tuning mine and I was impressed that he took the time with mine. You're more than welcome to come by and see the setup in person.
Old 11-07-2006, 08:53 AM   #28
Car: CGM 05 STI
Yes, Adam at Revolutions did the install and tune.
Old 11-07-2006, 01:57 PM   #29
How much did he chareg you for install for the meth kit. Also did you do the stage 2 or the stage 2 maf kit. What were your gains with meth, or did you not get dynoed before it. Thanks.
Old 11-08-2006, 02:10 PM   #30
Car: CGM 05 STI
It was awhile ago, but if I remember right it was like 4hrs labor at the shop rate. I went with the standard kit (Stage 2 I believe, not MAF) with Safe Injection option. I picked up 7 peak whp and 11 peak wtorque. There was a gain across the entire curve and boost came on quicker. This was also just on the stock turbo. So with a bigger turbo I am sure the gains would be quite a bit more.
