Old 09-15-2006, 11:19 AM   #16
Fav Mod: T2s and Recaros
Awesome, while you're at it you should have the APS turbo inlet installed too.
Old 09-15-2006, 12:47 PM   #17
Car: 06 WRX STI
Fav Mod: Snow Meth Injection
What gains does that give me and how much is it?
BicketyBam is offline   Reply With Quote
Old 09-15-2006, 12:51 PM   #18
I believe nhluhr gained 15whp up top with one and had quicker spool. It cost $275, and if a shop is doing the install, go for it. This way youll have zero restriction to the turbo.
Old 09-15-2006, 12:53 PM   #19
Car: 06 WRX STI
I am already spending $4500, so why not. I am sure they stock them. Thanks!
Old 09-15-2006, 12:58 PM   #20
No problem, although if we're going for the absolute most out of the stock turbo, I'd consider these additional small mods.
swap the 65mm cai for the 70mm cai
get one range colder plugs
get a gm boost control solenoid
you may also put on a stiffer wastegate spring like wolfplayer.
then throw meth on top of all this. i'd LOVE to see the results!
Old 09-16-2006, 01:31 PM   #21
Car: 06 WRX STI
What is a gm boost control solenoid and what are its benefits?
Old 09-16-2006, 01:34 PM   #22
520
STi > EVO... Wait what???
Car: 03 EVO
Fav Mod: stock :(
Send a message via AIM to 520
the stock boost selenoid is good to 22psi i think, but the gm selenoid should hold boost better...i think.
hopefully someone else chimes in.
Old 09-16-2006, 02:06 PM   #23
here's more info on it:
http://forums.nasioc.com/forums/showthread.php?t=870619
Old 09-20-2006, 11:33 AM   #24
Car: 06 WRX STI
OK - went back and forth a few times and this is the end result. In addition to the APS header/up-pipe & heatshield, Helix downpipe, HKS CArnon Ti catback, APS 65mm CAI, and Snow Methanol Kit, I asked about the following:
Warlbo fuel pump - added to project
colder plugs - added to project
Prodrive boost solenoid - added to project
70mm CAI - out of stock and claims there is no benefit on a stock turbo
Turbo inlet tube - claims no benefit on stock turbo, but I think there was a stocking issue there as well.
All in all I am happy with the project. I really hope I am impressed by the results. This is like $5k worth of work! I plan on bringing it to the strip and I am praying that it will run 12.5 (assuming I drive it right).
Old 09-25-2006, 09:37 PM   #25
Car: 06 WRX STI
Just got back from the shop - well worth the money. The hp was a little lower than what I expected: 314.7, but the torque is unreal: 401.3. It pulls like nobody's business! I added it to the dyno database and I will get the graphs up tomorrow. Now it's off to bed.
Old 09-25-2006, 09:46 PM   #26
Banned
Car: R.I.P WRB 06 STi
Fav Mod: ~ HKS Ti ~
Send a message via AIM to HKS whore
^^ wow .. speechless
HKS whore is offline   Reply With Quote
Old 09-25-2006, 09:46 PM   #27
Car: 05STi
Damn I need meth. I love torque. So what was your final breakdown of mods?
fuzz is offline   Reply With Quote
Old 09-26-2006, 03:57 AM   #28
Car: 06 WRX STI
APS equal length header and up-pipe
APS heat shield
Helix catted downpipe
HKS Carbon Ti catback
APS 65mm cold air intake
Snow Performance Boost Cooler
Prodrive Boost Solenoid
Walbro fuel pump
one step colder plugs
Old 09-26-2006, 05:22 PM   #29
Car: Cars and Airplanes
Send a message via ICQ to styx Send a message via AIM to styx
wow!!!!
styx is offline   Reply With Quote
Old 09-26-2006, 05:23 PM   #30
I'm Jim Halpert
Fav Mod: Ricer Flyby
great choice with exhaust
