Old 02-21-2008, 07:49 PM   #31
The Stig II
Fav Mod: Meth protune 323+/380+
Default Re: Whats best Meth Kit?
Originally Posted by flatfour562 View Post
^^^It looks exactly the same....
Labonte Motorsports makes great meth kit at great prices.
I had a Snow performance maf controller and it sucks... no power delay.
Replaced the pos snow controller with a Labonte maf controller and never had a problem since.
Funny, Labonte was the engineer for Snow for years...I do like his own designs better though.
jnprn2003 is offline   Reply With Quote
Old 02-23-2008, 09:27 AM   #32
Car: 07 STi Limited
The Snow controller sprays when cranking the motor. Dan changed his design and added a delay.
Originally Posted by Labonte MotorSports
Flatfour562,
Might I suggest you send the snow controller back and take a look at ours -
VC-MAF - Injection Controller for Fuel Injected Engines w/ MAF
It has the power up delay that you need. Snows boost maf controller is a knock off of our older VC-MAF that we do not manufacture anymore. One reason we changed the design over a year ago is because the issue you are having, false MAF signal on start up.
Best regards,
Dan
flatfour562 is offline   Reply With Quote
Old 04-04-2008, 11:52 AM   #33
i am running the aem meth kit i like it
rmontheweb is offline   Reply With Quote
Old 04-04-2008, 12:17 PM   #34
Car: Blue 06 STI
Fav Mod: FP Green
Send a message via AIM to rabbisti397
Aquamist
rabbisti397 is offline   Reply With Quote
Old 04-04-2008, 12:32 PM   #35
Car: 06 STI, 08 GSXR 750
Fav Mod: WC Lathe Werks Shift Knob
I'm guessing you're not on the stock turbo. This is why it's a bad idea to run an MAF based controller on a non-stock turbo. The problem you're talking about goes away when flow is based on boost.
Hitman83 is offline   Reply With Quote
Old 04-12-2008, 02:13 PM   #36
Car: 07 STi Limited
I do have a stock turbo. It's good to have a maf based kit for a small and fast spooling turbo.
http://www.labontemotorsports.com/ontrack/Mar08.pdf
Old 04-24-2008, 03:26 PM   #37
Cam'd GT35r
Fav Mod: STI to WRX SWAP!!!
Send a message via AIM to bankaiup Send a message via Yahoo to bankaiup
AQuamist HFS-5 ftw!
bankaiup is offline   Reply With Quote
Old 06-25-2008, 08:58 AM   #38
Car: 05 Legacy w/sti mani
Fav Mod: KW coilovers
Send a message via AIM to sutter2k
I don't think flowing based on boost is completely ideal either. With the stock turbo, boost tapers off, but its still flowing a lot of hot air and g/s. Alcohol flow should not drop off at that point. What do you set MAX flow at? 14psi?
I think flowing based on injector duty cycle works pretty well for the perrin kit.
Matt
sutter2k is offline   Reply With Quote
Old 06-25-2008, 09:05 AM   #39
Fav Mod: I do meth...
Aquamist HFS-5, hands down.
renns is offline   Reply With Quote
Old 07-11-2008, 06:30 PM   #40
Car: 2004 STi Blue
whats SMC's website?
04_Sti_Blue is offline   Reply With Quote
Old 07-11-2008, 06:49 PM   #41
Cam'd GT35r
it might be this.. idk www.smcenterprises.com
Old 07-12-2008, 04:18 PM   #42
Car: Silver Euro 07 STi
Labonte
VCS3G - 3D Injection Controller w/Dash Display
Old 07-12-2008, 10:53 PM   #43
Car: Silver 05 STi
I see that most people are recommending Aquamist, but which one is the best when running the stock turbo
amitchVT is offline   Reply With Quote
Old 07-12-2008, 11:57 PM   #44
Car: 06 Subaru WRX STi
They all mostly work the same and are all good on the stock turbo. It comes down to the price you want to pay with the failsafes you want and how it knows to spray whether its boost/maf/idc. Plus the quality
I myself prefer aquamist And it is what i run. I will never buy anything from Labonte as I think there way of bad mouthing other products on nabisco is wrong.
Old 07-18-2008, 07:08 AM   #45
Car: 07FXT. Fast
Matt
If you set your boost referencing controller up properly, the boost tapering will not cause the alcohol spray to taper.
If you run 20PSI as your peak boost, and you taper to 16PSI, simply set your max spray point at 16PSI. This will have 2 benefits.
1. You get full spray earlier, you can go more aggressive in that 16 to 20PSI range, which means not only do you make more power there than if you had part spray till 20, but you can map it to swing from 16 to 20 a bit faster.
2. You still have full spray as it tapers down to 16.
If set up properly, the performance difference is almost impossible to measure.
Aquamist is nice, but IMHO its a waste of money. Lots of bells and whistles that cost a ton, but dont make it any safer or give it the ability to make worthwhile power increases over a simple boost based kit. Of course the Aquamist guy will come in with a ton of "facts" abotu why their kit is SO much safer and will make SO much more power, however, the dyno tells a different story. The reality is that they arent making ANY more power, and that no failsafe in the world can stop that blank spot from getting to the cyl and either dump boost fast enough or switch maps fast enough. If any aquamist user is so sure, I challenge them to put a car on a dyno, and yank the plug on their alch kit at full spray at 25PSI. Nothing to worry about right? Exactly. The only foolproof failsafe is no alch kit at all. Short of that, setting your engine management up to listen for and respond to detonation is the safest way. Combine that with a simple boost dump failsafe and you are about as safe as you can ever get. The AEM kit is 400 bucks and comes with a failsafe. The Snow kit can reference MAF or boost for its metering, and metering it off the MAF will give you the same results as metering it off IDCs (actually, in my opinion, its better than duty cycle referencing, as the MAF will tell you how much air you are getting, I dont care how much FUEL I am using, I want to know how much air is going into the cyl. Take 2 cars, exact setups, but one car has 750cc injectors and one has 850cc injectors.
The car with the 850cc injectors will have lower duty cycle, and end up getting less of the spray into the cyl due to this. Now, I am sure you can set the alch kit up to compensate for that, but why?? Just reference the MAF if you are that worried about it.
I am not saying Aquamist is crap, or that duty cycle reference based control sucks, its just that "getting what you pay for" only works up to a point. And its not a $900 point. And that IDC based metering is largely marketing hype.
I agree about Labonte. Worked for Snow, left, took their designs with him, then badmouthed their products, which, at the time I am refering to, were the EXACT same thing he was selling. Some people argue that since he designed them, that they were HIS products. BS, he worked for Snow, designed them FOR Snow, to be sold as Snow products. They are Snow's products.
Davenow is offline   Reply With Quote
