Old 07-31-2006, 12:10 PM   #1
Fav Mod: Pro-Tune
Trader Rating: (16)
Default Meth Usage
I recently completed install of my CoolingMist Stg III stainless meth kit and was wondering about usage. Until I get tuned in August, I am just running water. I am going through a gallon every tank of gas. Is this about right?
Seems a bit much IMO. I have the controller set to come on at 8psi, reach 100% duty @ 21psi and tune knob to around 5. Help?
CB
Old 07-31-2006, 12:15 PM   #2
jph
turn it off until you get tuned.
J.
Old 07-31-2006, 12:19 PM   #3
I have a different system (Aquamist), and I'm injecting a 50/50 mix, but that usage seems really high. Typically, I run through a rear tankfull about every 4 tanks of gas, half that if I'm running it hard. However, my system is set to start injection @ 12 psi so it doesn't spray at all unless I have my foot in it pretty hard.
Why do you have it start at such low boost?
Old 07-31-2006, 12:20 PM   #4
Fav Mod: flushing toilets
...^+1
Delaware Subaru is offline   Reply With Quote
Old 07-31-2006, 01:17 PM   #5
Fav Mod: Pro-Tune
Trader Rating: (16)
Manufacturer's recommendation and my learning curve. Additionally, I would like additional air charge cooling in the gawdawful Texas heat. I will increase the min boost and check consumption.
Thanks for the help!
CB
