Old 07-10-2006, 03:12 PM   #1
Car: 05 STI
Send a message via AIM to RedlineSTI
Default Before getting Meth..
should I get Colder Plugs & Fuel pump? could I benefit from getting anything else?
RedlineSTI is offline   Reply With Quote
Old 07-10-2006, 03:31 PM   #2
you shouldnt need different plugs, and there is no need for a different fuel pump, because with tuning you should be leaning out your AFR's.
what kit are you going with? and plans for a failsafe system as well?
TitanSTI is offline   Reply With Quote
Old 07-10-2006, 03:39 PM   #3
Car: 05 STI
i'm going with the SMC kit. 50/50 mix. i'm new to this, i just decided to get meth about a week ago and probably ordering the kit sometime this week. So i'm trying to learn as much about it as I can before I get it.
Old 07-10-2006, 04:05 PM   #4
definatly check out the water injection forum on Nasioc. lots of good information over there.
i currently run a Coolingmist kit with their variable controller and ill be integrating a Aquamist DDS3 failsafe into the system this week. then i get my tune next monday.
good luck!
