Old 06-11-2006, 03:34 PM   #1
Fav Mod: Pro-Tune
Trader Rating: (16)
Default Meth Injection Install=TOTAL PITA
Have been working on the install for two days now and so far, all I have done is the custom 1gal tank and pump mount where the jack used to be. It's like 120 degrees in my garage and I can't continue with the install because I don't want to fill my car up with sweat.
Texas sucks. I have the lines ready to run to the front of the car and will install the controller in the glove box.
I am starting to believe in paying someone to install this crap. More trouble than it is worth.....probably the delerium talking.
CB
Old 06-11-2006, 03:41 PM   #2
Car: 05|WRB|STi
Fav Mod: Cobb Stage 2
Send a message via AIM to SoaReS
get one of those big a$$ fans from home depot. Then it will be nice and cool so you can concentrate.
SoaReS is offline   Reply With Quote
Old 06-11-2006, 03:48 PM   #3
Car: 05 STI
Yeah I think I would have just thrown that in as part of the install and pro-tune...But I do like doing as much I can myself....
Old 06-11-2006, 03:48 PM   #4
Fav Mod: Pro-Tune
Trader Rating: (16)
Oh yeah, believe me-getting one of those fans was on my mind today and the only thing I could think of to afford some relief. My gawd, it is so freaking hot.
Good thing is-The pump/tank install is super clean and stealth. I still have all of my trunk space.
The bad thing about one of those fans is, where would I put it? The thing is as big as one of my cars.
CB
Old 06-11-2006, 07:09 PM   #5
Car: 05 WRX STi
Fav Mod: Rare USDM SUBARU letters on trunk
Central air garage FTW I know I love mine.
I can understand your frustrations though. I used to have to do all my crap in a bank parking lot many years ago. I really don't miss those days. I like the sound of the stealth install though...you gonna have pics up soon??
Stang2STI is offline   Reply With Quote
Old 06-11-2006, 07:15 PM   #6
Muller Chevrolet
Fav Mod: a new 08 STi
smc kit?
Old 06-11-2006, 07:17 PM   #7
520
STi > EVO... Wait what???
Car: 03 EVO
Fav Mod: stock :(
Send a message via AIM to 520
i recomend not putting it in the glove box, you want to monitor it at all times. especially if its low etc..
Old 06-11-2006, 10:57 PM   #8
i just did the same thing last week. coolingmist trunk kit with the controller. took me about 10 hours total to install and i loved every minute of it, LOL. i also put the controller in the glove box and ran the lines from the trunk to the engine bay with the stock IC sprayer line, which runs over the driver side rear strut top, under the driver side door sill, through the driver side front fender well, and into the engine bay by the battery. i ran the wires from the pump in the same spot, through the dash and i used the cigarette lighter for my power and ground.
good luck with the rest of the install!!!
TitanSTI is offline   Reply With Quote
Old 06-11-2006, 11:02 PM   #9
depends on what kit you go with. for me, my controller only shows when it does a system check on power up and that the system is working properly, which is by a green light that blinks about 5 times a second. so i just pop open the glove box to check it and make sure it system check worked, then i close the glove box and the annoying light goes away, LOL.
my kit came with a float switch and clog nozzle/flow detector that are seperate from the controller and have their own LED's that i can mount where ever i want.
Old 06-12-2006, 05:16 AM   #10
Car: 05 STI
Fav Mod: Utec
If you rush an aftermarket stereo/sub install, the worst thing that can happen is a blown amp, fuse, or short.
If you rush a WI install... well you know. Take your time. When you are installing it think of it like you are installing a stereo that can never fail.
higB_0x05 is offline   Reply With Quote
Old 06-12-2006, 06:03 AM   #11
Fav Mod: Pro-Tune
Trader Rating: (16)
^^^Yeah, what he said. I have the Coolingmist Stg III stainless kit. I am going to mount my clog and low-level indicators in a blank panel by the IC spray switch.
I was going to route the SS line along with the IC spray line but route the wires along the passenger side and across the back seat and then into the LR trunk.
How do you get the line from the inside of the car into the fender well?
CB
Old 06-12-2006, 06:06 AM   #12
Fav Mod: Pro-Tune
Trader Rating: (16)
Oh yeah. I keep thinking what it would be like to have a meth leak at 150psi on a hot day. Scary for sure. That is why it has taken me two days to install just the pump/tank in the trunk. LOL
CB
Old 06-12-2006, 05:02 PM   #13
CB
there is a gromet on the firewall, to the left of the clutch pedal. thats where the stock one runs, there is also a lot of wiring there. you can just kinda pull the fenderliner out enough so that you can see where the hole in the firewall is and where the other lines run through it. i just took a razor blade and a screw driver and CAREFULLY put a hole in the rubber gromet by slicing it and then sticking the screwdriver in the hole i made. then you can CAREFULLY feed the meth line from inside the cabin so that you can see where its comming through, then use a pair of pliars and grab the end and gently pull it through. after that, i used the clips that hold the stock line inside the fender well, and just fed it into the engine bay.
just take your time and be careful. cause like the other guys said, if it fails, your motor most likely will too.
Old 06-12-2006, 07:08 PM   #14
Fav Mod: Perrin 30r Kit
routing the lines through the car is a peice of cake. dont give up, your halfway there.
