Old 05-11-2006, 01:05 PM   #1
Non-Reformed Meth Addict
Car: '06 WRB
Default How is meth nozzle installed?
Like the title says I'm curious how water/meth nozzles are mounted. As you can see in my sig the water/meth is in the works but I'd like to have as much info as possible.
Turbineguy is online now   Reply With Quote
Old 05-11-2006, 06:06 PM   #2
Car: '06 WRB
Anyone? Beuler? Bump.
Old 05-11-2006, 06:29 PM   #3
Car: 04 Blue STi
Ok, so you got a tmic I see so that is easy. You should have gotten instructions with the kit but it's like this..... Remove the tmic and get a 25/64 drill bit from sears or something and drill a hole on the flat surface on the bottom side of the the tmic right before the part that connects up to the TB where the boot covers. Once you do that, the nozzle sits right inside the tmic where you drilled the hole and take the hose and screw it in to the bottom of the tmic where the nozzle is sticking out. Make sure you use some red lock tight too. It's that simple. Any other questions just let me know.
ride_the_pony69 is offline   Reply With Quote
Old 05-11-2006, 08:40 PM   #4
Muller Chevrolet
Fav Mod: a new 08 STi
what he said...i'm sure the one you buy will be around the same...nozzle goes right before the throttle body.
Old 05-12-2006, 01:02 AM   #5
Car: '06 WRB
Thanks for the info. Sounds too easy. I was originally thinking I would have to drill my throttle body or something like that.
Old 05-12-2006, 08:34 AM   #6
Fav Mod: ALCOHOL INJECTION
Send a message via AIM to Ultimate CC
Right before TB between 3-6 inches for best atomization...
Ultimate CC is offline   Reply With Quote
