Old 04-26-2006, 12:43 PM   #1
IWSTI Addict since: Jan 2006
Trader Rating: (16)
Default Water Injection
Would it be safe to use the stock water line from the i/c spray reservoir with a water injection system? it would be much easier than routing a whole new line from the engine compartment to the trunk.
Thanks
ocorzo is offline   Reply With Quote
Old 04-26-2006, 12:47 PM   #2
Car: 04' wrb Cosworth STI
Fav Mod: nukeworker
IWSTI Addict since: Apr 2005
I don't think that the stock line will put up with the pressure and won't handle meth, if you change your mind.
modifyd is offline   Reply With Quote
Old 04-26-2006, 12:49 PM   #3
Car: 04 Black STI
IWSTI Addict since: Dec 2005
Send a message via AIM to reid-o Send a message via Yahoo to reid-o
Water/alky injection requires high pressures to atomize and also to inject in an already pressurized system.
Without the high pressures, the turbo would push the water back into the tank and/or you would have an incosistent non-atomized stream being introduced.
reid-o is offline   Reply With Quote
Old 04-26-2006, 02:05 PM   #4
Fav Mod: ALCOHOL INJECTION
IWSTI Addict since: Apr 2006
Send a message via AIM to Ultimate CC
You need to run new lines, the stock can't handle 150psi...
Ultimate CC is offline   Reply With Quote
Old 04-26-2006, 02:33 PM   #5
IWSTI Addict since: Feb 2006
Can we use the stock STI water spray tank atleast so that we can still get the low water warning light and not have to place a new tank? I'm guessing all the injection kits would just mount right up to the stock tank?
awdmonsta is offline   Reply With Quote
Old 04-26-2006, 02:40 PM   #6
Yea that works great, just need to tap one hole in the bottom and install the fitting and you will be good to go.
Dan
