Old 01-09-2006, 06:41 PM   #1
Car: 06 Ford F150 Lariat
Fav Mod: 4X4
Send a message via AIM to 05impreza
Default water sprayer reservoir & alchy kit
question: since i'm planning on having a fmic, is there anyway to use my water sprayer reservoir as the tank for my meth or 50/50 mix? is there a kit to do this? and has anyone done this?
i like the location of the tank, plus its hidden. if i don't use it for that, it won't get used for anything b/c of the fmic......
05impreza is offline   Reply With Quote
Old 01-10-2006, 06:55 AM   #2
Fav Mod: 4X4
no comments???? anyone know anything bout this?
Old 01-10-2006, 06:59 AM   #3
Car: 04 WRX STI
Fav Mod: TiC Super Shifter Set
Send a message via AIM to ASApilot
Thumbs up It can be done
Topspeed sells an inhouse kit that will use your trunk tank. The smc kit can be modded to use your trunk tank. Send your tank to steve up at smc and he will outfit the tank to be used in place of the washer tank up front.
jj
ASApilot is offline   Reply With Quote
Old 01-10-2006, 07:08 AM   #4
Fav Mod: 4X4
how much is topspeed's kit? and how will all this work w/ a fmic?
Old 01-10-2006, 07:09 AM   #5
Fav Mod: 4X4
if i buy their kit, can i just do all the work myself, or do i still have to send my tank to smc?
Old 01-10-2006, 07:33 AM   #6
Car: 04' wrb Cosworth STI
Fav Mod: nukeworker
I use the stock tank in the rear as well with a snowperformance kit. You can order all the parts from them to do the tank hook up. And you'll need about 20 feet of hose.
modifyd is offline   Reply With Quote
Old 01-10-2006, 07:45 AM   #7
Fav Mod: 4X4
where did you get the snowperformance kit at? that name is new to me.....
Old 01-10-2006, 07:52 AM   #8
Car: 2004 JBP STI
Fav Mod: Kakimoto Racing GT1.0Z
Send a message via AIM to Clarque
I am probably going to get this bad boy to hold more. (once I buy my kit)
Check it out
STi Spec C 12 Liter Intercooler Water Spray Tank
You can buy it here:
http://www.boxer4racing.com/turbo.htm
Clarque is offline   Reply With Quote
Old 01-10-2006, 09:02 AM   #9
Fav Mod: 4X4
i would love to have that tank, but its $160 at most dealers.....i think my sprayer tank will do, i'll have a map w/o alchy for everyday driving and then a 50/50 map, and then a meth map.....
Old 01-10-2006, 11:24 AM   #10
Car: 2005 & 2008 STI
Fav Mod: UR 35R and Hydra tune by Scott Siegel :)
Send a message via AIM to JDM-STI Send a message via MSN to JDM-STI
Anyone know how much the stock IC sprayer tank holds?
JDM-STI is offline   Reply With Quote
Old 01-10-2006, 11:41 AM   #11
Fav Mod: 4X4
i think its a little over a gallon...
Old 01-10-2006, 11:43 AM   #12
Car: 1997 JDM Subaru WRX
Fav Mod: Water Injection
I have a kit from Devil's Own and am pretty happy with it. I ordered mine with a solenoid(which you will need) to close when the pump is on so that water will not leak into your pipe. I am using my winshield washer bottle which is closer than the trunk but safer is better than sorry. I installed the kiy myself and it came with everything I needed. The kit also comes with a progressive controller that you can set when the pump should come on and trun off. Prices aren't that bad either.
IslandSTILE is offline   Reply With Quote
Old 01-10-2006, 07:10 PM   #13
Fav Mod: nukeworker
www.snowperformance.net
Old 01-10-2006, 07:20 PM   #14
http://www.smcenterprises.com/subaru.htm
This is what you want. A kit made just for our application.
Old 01-10-2006, 07:34 PM   #15
all bOOst
Car: pwn3d by bambi
Fav Mod: dual catch high performance pcv system
I'm interested in this, as well. I have the Aquamist 2d and want to use the stock tank as the reservoir. I've posted my question on Nasioc here:
http://forums.nasioc.com/forums/show...2#post12265282
forgedSTi is offline   Reply With Quote
