| Home | Register | Today's Posts | Go Premium | New Posts | | Mark Forums Read | Create a Member Journal | Marketplace |
| Platinum Member Feedback Score: 6 reviews Join Date: Nov 2007
| I know solder is the 'correct' way, but it is also the most permanent and easily detectable in the future. Would PosiTaps be an acceptable, reliable alternative? I use them on stereo installs without a second thought, but with something as sensitive as this, I want it to be as foolproof as possible. |
| | #2 |
| Spec C Club Feedback Score: 1 reviews Join Date: May 2009
| I have used EVERY method of connecting wires and terminals in my car and home I work in controls and if done right no method I know of really fails more than any other assuming you aren;t just twisting wires together and taping them up lol |
| | #3 |
| Spec C Club Feedback Score: 0 reviews Join Date: Jan 2009
| ive never had solder fail. ive never used positap (which looks better than those in my below statement) i have had other taps give me issues and ive renounced using them ever again. positap actually looks reasonable, i might give those a try next time i need to tap anything over solder. |
| | #4 |
| Platinum Member Feedback Score: 2 reviews Join Date: May 2006 Location: Riverside, CA
| there is not much room for a bunch of posi taps around the wire loom going to the ecu. You figure you will tap, power, ground, 2 wires to boost cut, and one idc wire. So that is 5 wires you will need to tap. I soldered mine. |
| | #5 |
| Silver Member Feedback Score: 6 reviews | i would think soldering would be the best idea. |
| | #6 |
| Bronze Member Feedback Score: 3 reviews Join Date: Aug 2008 Location: Pittsburgh
| Dont use T-Taps! Heres how i do remote starters/alarms. With this method i never had a car come back because the wire came loose. 1. Strip the insulator of the wire you want to splice into back an inch. 2. On the wire you are going to splice on, strip about 2 inches off the end of the wire. 3. Take a straight pick and make a hole in the wire that you stripped back an inch. 4. Push the other wire through the hole and wrap it around the wire. 5. Use electrical tape about an inch on each side of the exposed copper. This method is easily undone and doesnt involve solder. |
| | #7 | ||||
| Quote:
To all: if I decide to solder at the ECU, did you guys cut the OE wires and solder the 3 connections together? | ||||
| | #8 |
| If you decide to solder you could do away with the hole in the middle of the wire and just wrap the wires around, then solder. To be honest even if you dont poke the hole and just wrap the wires, then tape. That way has never failed either and its fast. |
| Thread Tools | |
Similar Threads | ||||
| How-To add LED Lights to STi Window/Lock Control Panel | LESLIEx317537 | GD-Interior | 62 | 04-26-2010 07:29 PM |
| How-To: Solder properly | Shakes | How-To / Install | 13 | 04-20-2010 11:56 AM |
| Pionner Avic F900BT Install help!! completed | starxidiam | GD-I.C.E/Security | 177 | 10-25-2009 10:04 AM |
| HOW TO: 05 Window Button/Door Lock Light Mod | VSGTS14 | GD-Interior | 17 | 06-29-2007 02:35 PM |
