| | #11 | |
| Authorized Manufacturer Feedback Score: 0 reviews | Quote:
However, you could be right under certain circumstances such as the same system is used on the same engine - but driver habit must be taken into account. Comparing an aggressive driver to a more sedate driver will make your claim more likely even the system setting is identical. I can explain why I make this line of reasoning. On the current market, there are basically three types of systems – Single stage (On/off), Progressive Pump Speed (PPS) and PWM Inline Valve (PWMV). The first two systems are lower in cost and tend to be more popular. Due to popularity, there are more companies fighting for a small niche market. Cost is a mainly the driving force to acquiring a larger market share, as they are basically of the same construction- a pump speed controller, a nozzle and a diaphragm pump. One item I believe is the root cause of the corrosion problems. Instead of putting an “inline solenoid valve” to shut off and start the spray instantly, a spring-loaded checkvalve is used. So what is the difference between the two… A motorised pump often runs up to 4000rpm will not stop and start on demand. Mechanical inertia always over-ride the control signal, however sophisticated the electronics are claimed. In other words, law of physic rules. A 20psi Checkvalve will let fluid through when the line pressure exceed 20psi and shut when the line pressure drops below 20psi. Regardless the type of system, Single stage or PPS, the water pump will at some time ramp to the high speed to create pressure. Let say the pressure peaks to 100psi, the user suddenly snap the throttle shut, either from braking or gear changing, the pump is not going to stop instantly but continues to make pressure and deliver fluid – Checkvalve has no ability to stop the flow as long as the pressure is over 20psi. This is the moment where “unplanned” fluid is being injected and line the inlet tract with fluid. Some fluid will find its way into the manifold via the small gap of the throttle plate. If throttle is not re-applied instantly to dry the walls, the residual fluid will slowly but surely cause corrosion, especially over a long period. Top chart: Manifold pressure and FIDC. Logged in real time road driving conditions. Bottom chart: Blue trace = PPS system real time flow - see the "over-run" relative to the manifold pressure- especially between "3-4" and after "5" An inline solenoid will prevent this as it will not be affected by the fluid pressure. It is governed by the internal spring (over one hundred psi) and electromagnetic circuit. Some PPS system makers only offer this as an option. As the PPS system market is driven by cost and no doubt end users will keep pressurising the makers to bring prices down. Since you will only get what you paid for, there is no uncertainty who is to blame. Lastly, why does the aggressive driver is more likely to accumulate internal corrosion? The simple answer to this is – more opportunity for residual fluid liquid lining the engine internal due to attaining higher pump speed so the pressure decade is slower, allow more “over-run” events. Some PPS systems are now offering 250psi pumps without an inline solenoid valve. This is a typical marketing hype without responsibilities… The PWM valve system uses an inline solenoid valve by default, so I did not need to make any reference to this regarding “deliver over-run”. This is only my view, do not treat this as gospel. Last edited by Aquamist; 07-11-2009 at 12:54 AM.. | |
| | #12 | |
| Platinum Member Feedback Score: 0 reviews
Car: JBP '04 WRX STi My Stuff: Subaru Parts Fav Mod: The Mad Dad UEL Header + Up Pipe really rounded out the other mods...Mmmm...torquey! Location: San Diego, CA Posts: 221
IWSTI Addict since: Sep 2008 | Quote:
Any pros and cons to water injection only, versus water and meth though? Thanks for your input. | |
| | #13 | |
The motec no doubt can send out PWM signal to control an inline valve or pump. Here is a general criterion that can be applied: PWM valve (full-lift type): - PWM Frequency between ......... 20Hz to 80Hz - Winding current demand ..........~1A - Valve break-through pressure ....... 200psi+ PWM pump: -PWM frequancy between 100Hz to 30Kz - 60W pump current demand ........... ~5A - 100W pump current drmand ......... ~8A - 150W pump current demand .......... ~12A Please note that motec needs some kind of electronic current amplify to drive the pump. A relay can handle the current but too slow to response to the required control PWM frequency. You best bet is using an inline valve (high speed) with Motec. I forgot to say, Aquamist HFS-5 (up to 80Hz) or HFS-6 (up to 260Kz) can receive PWM signal from motec. Last edited by Aquamist; 07-11-2009 at 07:22 AM.. | |
| | #14 |
| Lurker Feedback Score: 0 reviews Car: WRB 02 WRX & 04 STI Fav Mod: Coming Soon Posts: 1
IWSTI Addict since: Oct 2008 | great thread! Can you guys recommend brands? or at least give an example of a brand of each type? Thanks |
| | #15 |
| Authorized Manufacturer Feedback Score: 0 reviews | 1) On/Off system (singler stage): Every company have this one. 2) Progressive Pump speed system (PPS): Every company except Aquamist and FJO 3) PWM valve systems (same as fuel injection): Aquamist and FJO only |
| | #16 |
| Authorized Manufacturer Feedback Score: 0 reviews | . . Last edited by Aquamist; 10-28-2009 at 05:00 PM.. |
| | #17 |
| Senior STI Driver Feedback Score: 0 reviews Car: Black 07 STi Fav Mod: Girlfriend...new lightweight model Location: Chicago, IL Posts: 328
IWSTI Addict since: Feb 2008 | Feel like updating with the direct port info? |
| | #18 |
| Authorized Manufacturer Feedback Score: 0 reviews | I will put all the bits and pieces together as soon as I can get sometime. It is a worthwhile investment. Meanwhile, there is good write up on a GTR using this configuration here: Waterinjection :: View topic - 760whp skyline with direct port water injection (corrected) |
| | #19 |
| Authorized Manufacturer Feedback Score: 0 reviews | . . Last edited by Aquamist; 11-09-2009 at 02:27 AM.. |
| Thread Tools | |
Similar Threads | ||||
| Data Collection: Meth Injection Systems - DO YOU HAVE ONE? Answer this poll! | Majin | Water-Meth Injection / Nitrous & Intercooler Cooling | 33 | 11-05-2009 09:20 AM |
| coolingmist digital meth water injection systems! | coolingmist | GR-Engine/ECU/Power/Drivetrain Classifieds | 63 | 10-01-2009 01:55 PM |
| FS (NC) Perrin PWI-1 Water Injection | ///M Power | Engine / Drivetrain / Performance / ECU Reflash Units | 7 | 04-10-2009 07:26 PM |
| FS: Coolingmist Stage II (2) Meth / Water Methanol injection kit Allmost New!!! | letitroll | Engine / Drivetrain / Performance / ECU Reflash Units | 4 | 02-21-2008 07:03 AM |
| Water injection...and what you want and expect. Small rant | Gimmick | Water-Meth Injection / Nitrous & Intercooler Cooling | 4 | 09-02-2006 06:17 AM |
