Old 08-20-2008, 01:12 PM   #1
Car: 05 Aspen White STi
Fav Mod: KW V3s
IWSTI Addict since: Jul 2006
Default Spec C tank question
I am going to be getting an Aquamist kit soon, and have been debating whether or not to get the Spec C tank to go with it. It seems to me that at lower levels there would be much more room for the liquid to move around during heavy cornering, possibly starving the pump. Would it not be safter to run meth out of the smaller intercooler spray bottle, as it is much narrower and wouldn't allow as much "sloshing"?
Thanks for the input
ThePigSTi is offline   Reply With Quote
Old 08-20-2008, 03:11 PM   #2
Car: 06 Subaru WRX STi
IWSTI Addict since: May 2006
Default Re: Spec C tank question
both the stock ic and the spec c have differnt levels so. And as long as mount the outlet at the lowest possible place you shouldnt have to worry about it. The pump can starve for awhile before it dies. Plus as long as your pump is lower then the tank it will gravity feed it so if sloshing does occur it would have to be constant in order for the pump to run dry.
Here is my crappy mspaint drawing to help explain.
Old 08-22-2008, 06:36 AM   #3
Car: 04 Sti Wrb on Silver
IWSTI Addict since: Jul 2007
The tank has a small sump where the output line goes to the pump, you would have to be low low on fluid for the pump to run dry. Any way some pumps have a specific dry run time before they hit the bucket.
Old 08-23-2008, 02:07 PM   #4
Fav Mod: KW V3s
Great, thanks for the info guys. I can't wait to install it and get it tuned.
Old 10-28-2008, 07:52 AM   #5
Car: '04 STi PSM SZ55'd
Fav Mod: 472whp , 486ft/lb
IWSTI Addict since: Sep 2006
The Spec-C tank also has internal baffles to minimalize the sloshing. The center of the tank where the pump would be fitted is at near the lowest part of the tank .
VIR EURORALLY is offline   Reply With Quote
Old 11-09-2008, 08:53 PM   #6
Fav Mod: APS 3" turboback
IWSTI Addict since: Jan 2006
I run the spec-c tank into a smaller feeder tank that prevents the pump from sucking air during corners. Works like a charm. Track tested - mother approved.
With even 1/4 tank in the spec-c, the low level light will come on during hard turns. The baffles help some, but certainly not enough if you're planning on running on the track. If you keep the spec-c topped up regularly, you should be good though.
jwild is offline   Reply With Quote
