Old 07-10-2008, 05:27 PM   #1
Car: black 04 Subaru WRX
IWSTI Addict since: Oct 2007
Default is it better to run 50/50 or 100% meth
im just order a meth kit for my car and its comin in nex week but wut should be the mixture 50 50 or 100 percent meth. what are the pros and cons of eacH? thanks
stiblkngold is offline   Reply With Quote
Old 07-10-2008, 07:05 PM   #2
Car: 06 Subaru WRX STi
IWSTI Addict since: May 2006
Default Re: is it better to run 50/50 or 100% meth
There is a little gain over 50/50 to 100. It depends if you want to use the money to run 100% 50/50 gives you double the amount for the price. Plus a lot safer also.
Old 07-10-2008, 08:02 PM   #3
IWSTI Addict since: Aug 2006
Trader Rating: (14)
if it's a trunk mount, I would run 100%
blindfold is online now   Reply With Quote
Old 07-10-2008, 10:22 PM   #4
Why would you run 100% in a trunk mount and not 50/50
Old 07-11-2008, 10:00 AM   #5
Car: 427Vette/04E55AMG
Fav Mod: bc racing coilovers
IWSTI Addict since: Dec 2005
Trader Rating: (50)
Send a message via AIM to IMPORTIMAGE
100% ftw
even down here in FL where it's very hot 100% meth gets you the most results
Josh
IMPORTIMAGE is offline   Reply With Quote
Old 08-06-2008, 07:11 AM   #6
Fav Mod: Pro-Tune
IWSTI Addict since: Apr 2005
Trader Rating: (17)
What about the cylinder washing effect being worse with 100%? This especially on a DD.
CB
Old 08-06-2008, 07:18 AM   #7
Fav Mod: 4th gear wheelspin
IWSTI Addict since: Nov 2004
100% meth is much easier to mix
jays05 is online now   Reply With Quote
Old 08-06-2008, 12:33 PM   #8
A.X.D.
Car: 2004 STi
IWSTI Addict since: Apr 2004
from my meth sticky:
When using methanol injection, it is advised to mix with distilled water being that under-hood temperatures can turn methanol into steam being that methanol boils at 148.46°F (64.7°C) - this in turn can cause your car to not inject methanol.
i use a 75(meth)/25(distilled) mix
Old 08-06-2008, 12:42 PM   #9
I will add that 50/50 with a big nozzle (M15) just seemed like too much water. 75/25 meth/water was great but 100% was just so much easier in the long run.
Old 08-06-2008, 01:21 PM   #10
Fav Mod: Cobb Xaust!
IWSTI Addict since: Mar 2006
i have been running 50/50 for like 3 months and no problem, i havent really considered running anything else since in the aem kit is says not to put more than 50/50 so i have no choice...
oscargarza88 is offline   Reply With Quote
Old 08-06-2008, 01:37 PM   #11
Car: Your STi ;)
Fav Mod: Everything
IWSTI Addict since: Mar 2005
Any more water than 75/25 cuts down notably on the results. 100% is still best, but hard on pump seals, and easy to boil. A good trunk mount kit is STRONGLY suggested. 100% if you want easy and best results, 75/25 if you want to make sure your pump seals last forever
Siegel
Old 08-06-2008, 02:07 PM   #12
Siegel
I dont understan why a trunk mount would make in defference you are stll boiling the meth in the hose in the engine bay. Just not the tank.
Old 08-06-2008, 03:46 PM   #13
A.X.D.
Car: 2004 STi
depending on the pressure inside the hose, the boiling point should increase as pressure increases.
this is speculation: in the trunk, the tank may remain cooler than it's boiling point of 148.46°F - if this remains constant (liquid methanol in the trunk reservoir stays cooler than 148.46) then i would say it's plausible that the pressure in the line leading into the engine bay will force the boiling point up for the methanol and keep it in liquid form.
IMO, no speculation is better; mixing the meth with 25% distilled water is the best way to go for a street car.
Old 08-06-2008, 04:18 PM   #14
SO if everything is pressurized on the other side of a High speed valve that standard meth pumps are usually 125-150psi. the boiling point wouldnt change that much. Also that would assume that pump runs for a few seconds after the high speed vavle is closed.
Old 08-07-2008, 08:20 PM   #15
Car: 07 STI LTD #67
Fav Mod: Andrewtech built, Turbo XS tuned GT35R 624 AWHP. 528 AWTQ on VP C16
IWSTI Addict since: Oct 2006
I also use a 75/25 mix just to help stabilize the meth, and decrease its corrossiveness.
TAPOUT is offline   Reply With Quote
