Old 06-15-2008, 08:54 AM   #1
Car: 06 WRB STI
Fav Mod: XX protune
IWSTI Addict since: Mar 2006
Send a message via AIM to ebo03
Default Perrin progressive water injection
Anybody other than Matt (TheLimitedProject) have problems with the Perrin water injection unit? I also read some with the first batch had problems with the warning displays but got them sorted out by Perrin. Who's using it and have you had any issues? Thanks guys
ebo03 is offline   Reply With Quote
Old 06-15-2008, 04:03 PM   #2
Car: 06 Subaru WRX STi
IWSTI Addict since: May 2006
Default Re: Perrin progressive water injection
Everyone that i know that runs the PWI-1 has not had a problem. Just look at the 2d aquamist system as it is the same system with little differences. Aquamist designed the PWI for perrin. So its a good product.
Old 06-17-2008, 04:12 AM   #3
Car: 06 WRB STI
Fav Mod: XX protune
Are you running the kit? If so how do you like it?
Old 06-17-2008, 08:45 AM   #4
Im running the hfs-5 from aquamist. I know others that run the perrin or the 2d. and it suits them just fine
Old 06-25-2008, 10:09 AM   #5
Car: Silver 08 STI(stock)
IWSTI Addict since: Dec 2005
Send a message via AIM to sutter2k
Mine had that problem as well on first and 2nd batch of controllers, I just ignored early the warning and disconnected the fail safe. About a month ago it started indicating low flow at full boost. I backed off from doing any WOT runs. However a week later I the kit would not flow at all and just blows a fuse if I put one in.
This is after just under a year of use. My SMC pump from the kit before it failed after 4 months. Is there any kit out there that just works for years without worry about?
sutter2k is offline   Reply With Quote
Old 06-25-2008, 10:45 AM   #6
Car: 06 WRB STI
Fav Mod: XX protune
I've heard nothing but good about the Aquamist HFS-5. I'm leaning in that direction now if I go with meth
Old 06-25-2008, 11:16 AM   #7
Go on nabisco richard from aquamist is on there and he will tell you any information you want.
