Old 04-08-2008, 10:22 AM   #1
Car: 2007 OBP STi
Send a message via AIM to scoobiekid86
Default engine stumble on startup with meth?
anyone running meth have engine stumble upon a warm startup? i suspect this may be from meth condensation leaking from the nozzle after the car has been shutoff. the amount of meth is probably minimal, but would this cause any long term engine damage?
scoobiekid86 is offline   Reply With Quote
Old 04-09-2008, 10:36 AM   #2
Car: 06 Subaru WRX STi
Default Re: engine stumble on startup with meth?
You shouldnt have that much meth leaking from the nozzle after you turn your car off. what system are you running
halfelite is online now   Reply With Quote
Old 04-09-2008, 11:35 AM   #3
Trader Rating: (13)
warm start ups do tend to be slower since meth vapors enters into your combustion camber. Doubt it will do anything to your motor, you could install a one-way check valve into the line to see if i helps .
blindfold is online now   Reply With Quote
Old 04-09-2008, 07:45 PM   #4
Car: Blue 07 WRX STi
Fav Mod: Stage II
I just installed the Snow Performance kit and I'm having the same problem. The system energizes and prims itself when you turn the key on and a small amount of water/meth gets injected into the system, thus causing it to bog/stumble on startup. Where is your meth nozzle mounted? You need to buy the solenoid upgrade to prevent this from happening. It think it's this one: Snow Performance: Solenoid Upgrade
Try holding the gas pedal all the way down while cranking it- it shouldn't start, but it might if enough meth gets into the system. Do this for a few seconds, then let off the gas pedal (while still cranking) and it should start just fine.
riggy30 is offline   Reply With Quote
Old 04-12-2008, 02:09 PM   #5
Car: 07 STi Limited
I had the same problem.
Maf triggered meth injection - Water/Methanol Injection, Nitrous & Intercooler Cooling - NASIOC
flatfour562 is offline   Reply With Quote
Old 04-18-2008, 07:24 PM   #6
Car: 04 Sti Wrb on Silver
I have the same problem but mine is not maf controlled. Need to check if mine pumps at startup.
