Old 04-05-2008, 12:49 PM   #16
Fav Mod: sz55 external wastegate
Default Re: Need a stealth meth kit. Please help.
I'm going to post a write up of how I installed my meth kit using the stock IC water sprayer tank and mounting the pump behind it, it's very stealth I'll let you know when I post a write up about it. One of the best parts is that I made my own fitting for the tank using a 3/4" brass barb plug tapping it for 1/8" npt and using it where the small pump is normally plugged into.
Mycues1982 is offline   Reply With Quote
Old 04-05-2008, 12:57 PM   #17
Here are a couple of pics to show you what I'm talking about, everything fit perfectly with a couple cuts of the stock IC tank tray.
Old 04-05-2008, 07:02 PM   #18
Car: 06 subaru wrx sti
Fav Mod: royal purple
paint it flat black.
disturbed1 is offline   Reply With Quote
Old 04-05-2008, 07:21 PM   #19
Car: 06 STI, 08 GSXR 750
Fav Mod: WC Lathe Werks Shift Knob
Looks good. this is the type of install I'm planning
Hitman83 is offline   Reply With Quote
Old 04-05-2008, 07:44 PM   #20
Car: 06 Subaru WRX STi
Post a parts list of what you used to tap the stock pump location please.
Old 04-05-2008, 08:34 PM   #21
no parts list really, went to Home depot to find something and came up with a 3/4" brass barb plug that I tapped for 1/8 npt. I have more pics of it but the fitting actually worked perfectly cause the coolingmist piece threaded in flush to the taper of the plug. I'll post a pic.
Old 04-05-2008, 08:44 PM   #22
Old 04-06-2008, 06:15 PM   #23
Nice and it seals ok using the stock rubber gromet on the tank? I will have to give it a try.
Old 04-06-2008, 07:08 PM   #24
yep I tested it before installing the tank and there are no leaks
Old 04-06-2008, 07:31 PM   #25
Problem is the pumps aren't quiet, so you are going to have to explain what that new noise is coming from the trunk every time it kicks in.
Biznatch231 is offline   Reply With Quote
Old 04-06-2008, 07:48 PM   #26
Car: 05 WRX STI OBP
Fav Mod: learning how to heel toe
did u try this out theres stuff is really great. Element Hydramist Water
Old 04-07-2008, 04:19 AM   #27
Yea but when it kicks in your car is usually louder than the pump.
Old 04-07-2008, 09:59 AM   #28
good point but I don't think she'll hear it over the N1
Old 04-07-2008, 01:18 PM   #29
Car: 04 WRB/G STi
Fav Mod: Sz49 + Meth
I've got an N1 and you can't hear my pump.
Boostpimp is offline   Reply With Quote
Old 04-14-2008, 06:42 PM   #30
Car: 07 STI LTD #67
Fav Mod: Andrewtech built, Turbo XS tuned GT35R 624 AWHP. 528 AWTQ on VP C16
Well, I installed my big HFS-5 pump and I'm using the stock tank as well. I am keeping the stock I/C sprayer pump and float so I have the light on the dash, and if I need to empty the tank for any reason, I can do it with the stock pump and lines.
TAPOUT is offline   Reply With Quote
