Old 03-24-2008, 05:13 PM   #16
Car: 07 STI LTD #67
Fav Mod: Andrewtech built, Turbo XS tuned GT35R 624 AWHP. 528 AWTQ on VP C16
Default Re: too much meth = knock?
Most race shops recommend running copper plugs because copper will melt before most other metals. That way (in theory) when you run your temps too high, the $2 plug goes instead of a piston or valve.
TAPOUT is offline   Reply With Quote
Old 03-24-2008, 05:20 PM   #17
Non-Reformed Meth Addict
Car: '06 WRB
Fav Mod: 18g on meth. I gotz no lag.
^^^+1. Another safety reason for those high strung motors.
Old 03-26-2008, 07:09 PM   #18
Car: 06 subaru wrx sti
Fav Mod: royal purple
oohhh thats why your going trough plugs. there cooper. try iridium and then see what happens. also i thought that our motors are sleeved with steel or cast iron because the blocks are aluminum. so i dont see how the meth would eat at the cylinder walls.
disturbed1 is offline   Reply With Quote
Old 03-26-2008, 08:11 PM   #19
Car: wrb 2005 STi
Fav Mod: FP GREEN
Send a message via AIM to blueman05
how often should we be changing plugs??? im 50/50 meth for a yr now but i run 2 maps and dont always have meth on.... also im using ngk one step colder what should they be gapped to and what should i use to gap them?
kevin
blueman05 is offline   Reply With Quote
Old 03-26-2008, 08:56 PM   #20
gap to the factory specs unless your tuner asks you to.
Old 03-27-2008, 02:47 AM   #21
Car: wrb 2005 STi
Fav Mod: FP GREEN
and what are factory specs and whats the best tool to do it with?
Old 03-27-2008, 06:26 AM   #22
look under your hood i beleive its about 40 or 45.go to any autoparts store and pick up a spark plug gapper for about a dollar. they ussually have them at the check out counter.
Old 06-08-2008, 04:41 PM   #23
i run 100% denatured alchy for 1.5yrs and the stock ones are fine
BrigadoonB is offline   Reply With Quote
Old 06-09-2008, 07:00 AM   #24
Car: 04 WRB STi
Fav Mod: Hydramist + GT52
Send a message via AIM to RemlapaN
So back to the OP...
You are asking us if your car is experiencing rich knock, but you're not posting any logs and you're not telling us what AFR + timing + boost you're going for.
Please give us enough info to intelligently respond to your questions
RemlapaN is offline   Reply With Quote
