Old 11-01-2007, 09:32 AM   #1
Car: 06 Subaru WRX STi
Default Meth Nozzle Placement
I have been working on my setup and come to a snag I figure a nozzle post and after the IC Would be the best placement for me as it does not get cold enough in SoCal to really freeze. What are others take on this. And even if I do go Somewere cold enough to freeze i just switch off the meth map.
And individual port as that is way way over my head and more then likely not even a DD solution
Old 11-01-2007, 11:59 AM   #2
Car: 08 CBR1000RR
Fav Mod: None
Default Re: Meth Nozzle Placement
What percentage of meth / water do you plan on running? What type of intercooler setup. I need some specifics to give you some suggestions please.
Old 11-01-2007, 12:09 PM   #3
Car: 06 STI 03 EVO
Fav Mod: WIFE
Send a message via AIM to ray@turbotek
yes what he said, help us help you
ray@turbotek is offline   Reply With Quote
Old 11-01-2007, 12:39 PM   #4
Originally Posted by halfelite View Post
...Somewere cold enough to freeze i just switch off the meth map...
Even if you're running 50/50, you won't freeze the solution unless you park it down in Antarctica for a few days...the freezing point is about -45f. PM mxpop about the double nozzle placement concept - that's what he runs and he really thinks it helps a lot.
Old 11-01-2007, 02:36 PM   #5
I will be running 50/50 And a larger topmount. Sorry to leave that out lol
Old 11-01-2007, 05:37 PM   #6
Car: 08 CBR1000RR
Fav Mod: None
You plan on running two nozzles from the HSF-5 kit? Thats the pain with running a TMIC, not enough choices as to where to put the nozzles. I would probably still mount both of them before the throttle body, 180 degrees apart. I'm not to keen on the spraying prior to the intercooler, but that just me.
Old 11-01-2007, 05:42 PM   #7
The Stig II
Fav Mod: EFI Logics tune
Had my nozzel mounted on the underside of my APS TMIC right before the outlet of the intercooler.
Joe
jnprn2003 is offline   Reply With Quote
