Old 10-23-2007, 11:45 AM   #1
Car: Black 05 WRX STI
IWSTI Addict since: Oct 2007
Default Water/ meth kit
I'm am looking into getting a water/meth injection kit befor my pro tune. One thing i can't find an answer to though. The kit lets you pull more boost on stock turbo, question is if i'm not driving hard do i need to reflash and turn off the injection. This is the only question i cant find an answer to.
WyoSTI is offline   Reply With Quote
Old 10-23-2007, 11:50 AM   #2
DOMINATOR
Fav Mod: Strut Clunk
IWSTI Addict since: May 2005
Default Re: Water/ meth kit
I think you have a lot more researching to do on how meth kits work. Most meth kits start spraying when you hit a certain boost level, as long as you are below that boost level, the kit will not spray. On the other hand, there are some kits that start spraying based off of maf readings or other variables. Meth injection is something you should research thouroughly before putting it on your car. You want to make sure you understand all the benefits and consequences and decide which meth kit best suites your needs.
Old 10-23-2007, 12:39 PM   #3
Car: 05 Subaru WRX STi
Fav Mod: FP Red and Meth
IWSTI Addict since: Mar 2005
Send a message via AIM to luSTI
Im a little sketchy on your wording, but you will need a completly seperate map for when youre running meth injection. You can get it as a realtime map so you can swap on the fly without turning the car off, but you will HAVE to swap maps if you run out of meth or disconnect it.
luSTI is offline   Reply With Quote
Old 10-23-2007, 01:29 PM   #4
Car: 427Vette/04E55AMG
Fav Mod: bc racing coilovers
IWSTI Addict since: Dec 2005
Trader Rating: (50)
Send a message via AIM to IMPORTIMAGE
i can help you out, give me a call at 239 540 6385 and i'll help direct you
IMPORTIMAGE is offline   Reply With Quote
