Go Back   IWSTI.com: Subaru WRX STI Forums > Owners' Lounge > Warranty / Service Issues
Old 07-22-2007, 10:14 PM   #16
Car: 05 Subaru Impreza WR
Fav Mod: Me in the seat!
IWSTI Addict since: May 2005
Send a message via AIM to deadman_racing Send a message via MSN to deadman_racing Send a message via Yahoo to deadman_racing
Default Re: 30,000 mile service and now a miss
fly -
it was fine the rest of the time i was on my vacation. the idle miss didnt start until i was home, like, got home that night, parked it, and next day on the way to work noticed it was idleing kinda crummy. i dunno, im just frustrated at this point, i am one of those "it should b perfectly smooth" kinda guys, maybe i am just way off base and should realize no matter hwat u spend on a car it wont b perfect. the idle miss is one like my old camaro had, where its sitting there smooth as can b, and then a hiccup kinda thing from the motor, u dont hear it, but u feel it in the car
deadman_racing is offline   Reply With Quote
Old 07-22-2007, 10:28 PM   #17
Car: Gt35R STi
Fav Mod: JrTuned FTW Bro
IWSTI Addict since: Dec 2005
Send a message via AIM to boostedrex05
is it just at idle? or in the mid rpm range if they checked the plug's they might have broken one or worse a coil. also check for Vacc.. leaks you will hear it should make a loud sucking of air noise if it's that. you could also have a leak on the MAF inspect that if they tried to clean it with none MAF cleaner it might be damaged it not sealed tight.
boostedrex05 is offline   Reply With Quote
Old 07-22-2007, 10:34 PM   #18
Car: Gt35R STi
Originally Posted by deadman_racing
fly -
hum sounds weird maybe a clog in the fuel filter. oh buy a oil catch can asap even do the line off the PCV when i just took out my fmic and stuff i had oil in everything from blow buy. Royale Purple oil is crap really stear clear from it. my next try is the motul.
but the oil catch can will keep all that oil out of the sensor's witch clog's them and screw's with the reading's that may be your issue here also there so many thing's it could be it's hard to say without seeing it for myself
Old 07-23-2007, 02:55 PM   #19
Car: Silver 07 Legacy
IWSTI Addict since: Mar 2007
There should be no reason to change Plugs at 30k.
Basically it should be pretty much these items
Oil change and filter
Rotate/balance tires
Replace Air Filter
Service transmission
Coolant exchange
Brake fluid exchange
adjust rear parking brake
Inspect the vehicle over for wear with brakes, clutch, belts, hoses, other fluids, axle and steering boots, etc.
That is what we do for a 30,000 mile service for WRX/STI
Blackfang is online now   Reply With Quote
Old 07-26-2007, 12:41 PM   #20
they wanted to do plugs, but i told them no
- there are no obvious vaccum leaks
- yes it only is at an idle
- ill check th eMAF and air cleaner tonight
