Old 07-10-2007, 10:28 AM   #1
Car: OBP 06 STi
Fav Mod: blitz nur spec turboback - invidia v3 dp
Send a message via AIM to jredman6
Default going for oil change
im going to the dealership. is there anything i should ask for or would have them tell me?
if im flashed to stage 1 on my AP should i reflash to stock?
jredman6 is offline   Reply With Quote
Old 07-10-2007, 10:39 AM   #2
Fears smelly diff fluid
Fav Mod: Invidia G200
Default Re: going for oil change
This topic has been covered a bunch already.. do a search and you will find more info.
If you can change the oil yourself i wouldn't even bother with the dealer. If your just going to the dealer for an oil change, there is no reason the dealer will tinker around with your ECU unless you tell them something is wrong with the timing, misfiring, or something like that.
As for other things to have them look at, depends on how many miles you have. Check your owners manual and see what they recommend at each mile mark. Personally, i think it is much cheaper and pretty easy to do most of that stuff yourself. For me, the drive to the dealer, and then having them work on my car, and the drive back would probably take just as long / longer than if I did my own work. Plus I can sleep better at night knowing that nobody F'd with my car!
Old 07-11-2007, 12:05 AM   #3
Car: 2006 Aspen White STI
Fav Mod: Trading the WRX for an STI
Don't forget to buy a Fumoto oil valve--best thing I ever bought for my maintenance efforts.
Shewillbemine is offline   Reply With Quote
Old 07-11-2007, 02:03 AM   #4
Car: OBP 2004 Subaru WRX
Fav Mod: K&N, Intake Silencer, Falken FK452's
noob question: whats a fumoto oil valve, and what does it do?
MasterMind is offline   Reply With Quote
Old 07-11-2007, 04:29 AM   #5
Car: 07 OBP STI
Fav Mod: Sundays and Boxers
The Fumoto oil drain valve is only the best creation ever for the do-it-yourself oil changer.
http://www.fumotovalve.com/
Actually comes from the factory on some cars. I believe my friends Ford truck had one installed when he bought it from the dealer new.
It is basically just a valve that you screw into the spot of your drain plug on your car. After that, you never have to mess with you drain plug again. You just turn the knob, the oil comes out in a very controlled mannor. Then you turn the knob back to the closed position and you are done. I purchased the one with the "nipple" on it, which allows you to attach a rubber tube, so you can literally aim the oil to drain wherever you would like. I got my first oil change at the dealer since it was free, I have done two since and its a breeze. The only messy part is the oil filter, but after you figure it out (or just buy a large drain pan) then you will never see a drop of oil hit your driveway. Also makes it very easy to grab a sample of oil to send in for analysis if you are into that.
I purchase my oil filters from the dealer. Used normal 5w30 on my 1st and 2nd changes. At about 8k miles (I see you have an 04, so you probably have well over that), switched to mobil 1 5w30. Have not burned any oil yet.
Its your best option. The dealer charges an arm and a leg for an oil change, especially a synthetic oil change.
StylesJim is offline   Reply With Quote
Old 07-11-2007, 08:42 AM   #6
Man that Fumoto valve is quite expensive... id rather just get that socket wrench out and save $30
Old 07-11-2007, 09:58 AM   #7
Trust me, it is well worth the money--can you imagine changing your oil simply by flipping a switch?
Old 07-11-2007, 05:05 PM   #8
its genious! i've never been to a dealer for an oil change. i've heard that some manufactures will void warrenty if a diy oil change is done.
