Old 06-11-2007, 01:35 PM   #1
Default Bearings replaced under warranty?
I tried searching but couldn't find anything.
Has anyone gotten their bearings replaced under warranty? I am getting pad knockback even on the street now. It seems like its a well known problem for the 04's to have weak hubs. Is this something that Subaru will fix under warranty? I am pretty sure they won't issue a recall.
I read that some people got them replaced under the 5yr/60k warranty but it seems like my dealer won't replace anything under warranty. Is there a fool proof way to get the dealer to replace them under warranty?
na-STi is offline   Reply With Quote
Old 06-11-2007, 01:58 PM   #2
Car: 04 WRB STi
Fav Mod: JDM STi Recaros
Default Re: Bearings replaced under warranty?
As far as I know they usually don't warranty it after the 3 yr/36k warranty. I'm hoping mine don't go out too, but it does suck for us 04 guys. Time for the 05 swap
yakmasterjack is offline   Reply With Quote
Old 06-11-2007, 02:11 PM   #3
I was thinking of doing the 04-05 hub swap but that is so expensive. I would rather just trade my car in for something else. The problem is, there is no other car I want right now. I would wait for the Evo X or 08 STi but I am not making the same mistake by buying the first model year again.
Old 06-12-2007, 10:53 PM   #4
Anyone get their bearings replaced under the 5yr/60k warranty?
Old 06-13-2007, 02:39 AM   #5
I'm sure if you made a good enough argument and didn't have extensive afterkmarket modifications and wheels with a crazy offset you should have no problem.
illt3ck is offline   Reply With Quote
Old 06-13-2007, 03:45 AM   #6
Car: 05, Subaru Impreza W
If you have non-stock wheels with an offset that is quite different than stock...you will probably have trouble with your warranty. The wrong offset can and will destroy wheel bearings.
BlueGold is offline   Reply With Quote
Old 06-13-2007, 03:57 AM   #7
Do a search; just yesterday I was reading about a vendor who was putting together a 04/05 hybrid hub swap kit. Upgrade the bearings, but keep the 5x100 bolt pattern, and the struts, etc. Should be dramatically less expensive than a full 04->05 hub swap.
Old 06-13-2007, 08:37 AM   #8
Yeah I saw that. It's only a savings of $50 or so. It just makes it so you wouldn't have to get the 5x114.3 wheels, rotors, and shocks. Those pieces are no big deal to me since I can sell my wheels and buy some 05+ takeoffs for not much more. Rotors and shocks are something that I wanted to upgrade anyways.
I would also have to pay for around 4 hours of labor since I cannot do this install myself. This route is still very pricey.
Old 06-13-2007, 08:42 AM   #9
I still have stock wheels. I was planning on getting some camber plates. Do you think that the camber plates along with the mods in my sig will be enough for them to deny me a bearing replacement?
