Old 05-29-2007, 01:00 AM   #1
Default Clunking from struts
my rear struts are clunking, I know others have had this problem and have had it replaced under warranty...my question is for a suspension issue should I have any problems with getting it covered under warranty if I have a catback and intake? I know Subaru dealers are horrible with transmission issues if you have any mods whatsoever...thanks
emlS03 is offline   Reply With Quote
Old 05-29-2007, 02:26 AM   #2
STI Guru
Fav Mod: grip.
Default Re: Clunking from struts
that all depends on that particular dealer... its hit or miss.
Old 05-29-2007, 02:35 AM   #3
Fav Mod: LS6 and T-56 swap :D
Go tell them to eat **** if they don't cover the struts because of a catback and intake. There is no reason why they shouldn't unless they are idiots or assholes... or both. I seriously doubt you'd have any problems.
Rookie84 is offline   Reply With Quote
Old 05-29-2007, 05:26 AM   #4
You should be fine. If they hassle you, remind them about Magnusson-Moss and ask them how exhaust and intake have anything to do with struts.
Old 05-29-2007, 10:13 AM   #5
The replacements will do the same thing after a while. I just smeared some grease on the shafts & the clunk goes away (for a while).
RBMike is offline   Reply With Quote
Old 05-29-2007, 11:02 AM   #6
Seriously? That really sucks...
Old 05-29-2007, 11:22 AM   #7
Fav Mod: Teh Mature Diffuser Will Return!
Send a message via AIM to KiR DieseL
My right rear is clunking but mostly when theres more than 1 person the car... I went to the dealer about it this past saturday and they said that its not bad enough yet to replace the strut... I did get free brake pads so i didnt complain
Im going to get my strut replaced before my warranty runs out.
KiR DieseL is offline   Reply With Quote
Old 05-29-2007, 11:25 AM   #8
Send a message via AIM to straightouttajersey
strut clunk is inherent with our struts. You can go ahead and get these replaced by warranty and your new ones will eventually clunk as well. Take the 5-10 minutes it takes to jack the car up and smear some grease on the strut shafts and call it a day. It's really not worth the hassle to go to the dealer, force them to cover it under warranty, and end up back there when the new ones do it all over again...
straightouttajersey is offline   Reply With Quote
Old 05-29-2007, 06:27 PM   #9
Car: 2006 Subaru WRX STI
Fav Mod: Maddad DP and P&L Catback, stage 2!!!
Send a message via AIM to haroman311
they cant deny service because of those, if u had some like tein stechs and ur struts blew, i can understand that. if u had turboback and u fouled out ur o2s i can understand that, but they cant deny u struts because of something totally irrelevent to what the problem is.
haroman311 is offline   Reply With Quote
Old 05-29-2007, 06:50 PM   #10
Car: 06 Subaru WRX STi
Fav Mod: The Hooptie
Send a message via MSN to jungo75 Send a message via Yahoo to jungo75
That shouldn't be a problem. I have cat back and never had anybody from Subaru say something. I had the same problem and took it in for service. Supposedly it was a "mount". Well, last week the damn noise came back and I'm wondering what are they going to say it was.
jungo75 is offline   Reply With Quote
Old 05-30-2007, 12:29 AM   #11
Originally Posted by straightouttajersey
strut clunk is inherent with our struts. You can go ahead and get these replaced by warranty and your new ones will eventually clunk as well...
I see..anyone know the mechanical basis for this? Or is it just a crap design..?
Old 05-30-2007, 01:08 AM   #12
Moderator
Car: 05 Ram 3500 CTD
Fav Mod: Majin
its a combination of a piss poor strut and bad suspension geometry.
all of the information you seek is in the warranty/service section in a thread titled rear strut clunk log. it will be the sticky at the top of the page.
I anticipate this thread will get
Old 05-30-2007, 01:11 AM   #13
cool thanks!
Old 05-30-2007, 01:13 AM   #14
Moderator
Fav Mod: Majin
both my rears replaced. I really dont think the greasing the shaft trick is worth it. it youre going to do it, do it right and either replace the strut (mine lasted 18-30k miles) or take the strut apart and re lube the seals. Just know, that there are 2 kinds of clunk. I can be cured by greasing the shaft, the other is a strut failure and the ONLY fix is to have it replaced.
If you decide to pull the strut apart and fix it yourself, do it quickly because the longer you drive on that clunk, the more damage you do to the seals.
Old 06-03-2007, 04:13 AM   #15
Originally Posted by lackskill
... I can be cured by greasing the shaft...
LOL I bet you can!
Thanks for the responses and all the info!
