Old 04-27-2007, 07:13 AM   #1
Car: OBP 06 STI
Default Inspection covered under warrenty?
Im going to the dealership for a general 15k mile inspection (already changed oil and filter just need inspection) and want them to check the clutch for any abnormal wear and the turbo since it seems to not be boosting correctly lately.
My question is does the warrenty cover inspection of warrentied parts or will I have to pay the 100-200 bucks to get my clutch and turbo checked?
jsnuff1 is offline   Reply With Quote
Old 04-27-2007, 07:14 AM   #2
Poor Speed Racer
Car: 96 328
Default Re: Inspection covered under warrenty?
normally warranty only covers "problems" with the car. So odds are you'll have to pay.
Old 04-27-2007, 07:23 AM   #3
Car: 05' STi
Fav Mod: JDM Fogs
This is what they do for the 15K service.
Vehicle: 2005 IMPREZA WRX STi
Interval: 15000 miles / 15 month service
Action Description
Replace Engine oil
Replace Engine oil filter
Inspect Disc brake pads and discs, front and rear axle boots and axle shaft joint portions
Perform Inspect brake lines and check operation of parking and service brake system
Inspect Clutch operation
Inspect Steering and suspension
Perform Rotate and Inspect Tires
I don't know about the boosting issue. But they will check the clutch for proper operation.
