Go Back   IWSTI.com: Subaru WRX STI Forums > Owners' Lounge > Warranty / Service Issues
Old 02-19-2007, 11:00 PM   #1
IWSTI Addict since: Oct 2006
Default Cruise Control Stopped Working
So i was driving to work yesterday and i went to set my cruise control and it would not work. It turns on when i push the button, but when i push down it will not SET. What could be wrong?
evoxd is offline   Reply With Quote
Old 02-19-2007, 11:33 PM   #2
Car: 08 STi, SSM
IWSTI Addict since: Dec 2005
Is your check engine light on?
Old 02-20-2007, 12:16 AM   #3
No, there are no CELs
Old 02-20-2007, 10:10 AM   #4
Car: 06 Subaru WRX STi
Fav Mod: My right foot...
IWSTI Addict since: Nov 2004
I believe that the cruise control has a switch that sometimes can go bad. A visit to the dealer should fix it.
pantag is offline   Reply With Quote
Old 02-26-2007, 11:57 AM   #5
Well i did not notice this at first but the Horn has stopped working also. And the hazard button does not turn on the blinking lights. Is there a fuse or somthing that runs all this stuff?
Old 02-26-2007, 12:01 PM   #6
STI Master
Fav Mod: Whooshing sounds
IWSTI Addict since: Nov 2003
The owners manual should have a fuse chart.
Use that to check which fuse/s control the operation of the horn, CC etc. and then check the fuse to make sure it's not blown out, if it is, replace it with the same fuse.
Old 02-27-2007, 01:36 AM   #7
Fuse was dead, got a new one in and everything is working great. Thanks for the help
Old 02-27-2007, 12:27 PM   #8
Glad you resolved the issue. So, only one fuse was blown and it affected all the other equipment as well?
Old 02-27-2007, 12:42 PM   #9
Fav Mod: Alcantara...Everything!
Its always a damn fuse
Good work.
Old 03-01-2007, 02:19 PM   #10
Car: 08 STi, SSM
Question is. Why did the fuse blow? They don't normally just randomly blow.
Old 03-09-2007, 06:41 PM   #11
Fav Mod: fp Red 8cm
IWSTI Addict since: Mar 2007
I have a Hydra standalone and my cruise dosen't work? Anybody?
dsnuts02 is offline   Reply With Quote
Old 03-11-2007, 06:23 PM   #12
Car: 08 STi, SSM
Umm...I'm not sure if you're joking around but if you have a Hydra, you won't have cruise control anymore. Unless they've radically changed it since I last did some research on them.
