Old 12-20-2006, 10:38 AM   #1
Car: 05 STI - Cobb Stg 2
Fav Mod: Curb Feelers (driver side)
Default Extended warranty - $1500 5 years/50K miles
my car has 29K miles on it, and the warranty expires @ 36K. the car has been real good to me since i got her at 19K. I drive 2K miles/month to and from work. and some minor spirited gatherings at the local racetracks.
<O
Problems so far:<O
Right rear strut blown - replaced no cost/labor.<O
<O
Brakes (?) - i think they're low, but Subaru says that they are 4ml and 5ml respectively and they cant replace them until they're 1.5ml.<O
<O
should i get the extended warranty just before mine expires. or is it BS?<O
<O
if any of you have personal stories of the pros/cons of extend warranties i would like to hear them.<O
<O
cheers.<O
RAS_STI is offline   Reply With Quote
Old 12-20-2006, 10:40 AM   #2
OT stealth mod
Car: 06 obp sti
Fav Mod: Vodka injection.
Send a message via AIM to dailydriversti
I would say if you are going to mod the car quite a bit, i wouldn't do it, unless you have a mod friendly dealer.
Also, i think there is something wrong with your comp.
dailydriversti is offline   Reply With Quote
Old 12-20-2006, 10:45 AM   #3
the only mods i have are TBE and AP. thinking about throwing some sway bars on her. thats all. and oh yeah..maybe some springs. 20% chance of the springs.
Old 12-20-2006, 12:37 PM   #4
Car: 04 Subaru WRX STi in
Fav Mod: what mods?
its got those same sort of questions, i think i just need to go into the dealership and ask.
Glycerin is offline   Reply With Quote
Old 12-20-2006, 12:44 PM   #5
My dealer (Barber Subaru in Ventura, CA) will replace pads less than 3mm under the 3/36 warranty.
<O
Problems so far:<O
<O
<O
<O
<O
cheers.<O
francoej is offline   Reply With Quote
Old 12-20-2006, 01:00 PM   #6
i'm not sure why those smile faces are there.... maybe cause i used Word to edit it before moving over to the board.
either way. sorry.
Old 12-20-2006, 01:02 PM   #7
the only thing a dealer will say is "Buy it". people on this forum will provide better reasons for getting it or not.
if i asked the dealer everytime i had a question...i'd be broke and have a bunch of stuff i wouldn't need.
Old 12-26-2006, 04:48 PM   #8
Car: Black '05 STi
Fav Mod: Dealer delete option.
From SOA extended warranty web site.
http://www.subaru.com/owners/addedse...CT_COMPARISONS
Contract Comparisons
To research details of the Subaru Extended Service Contract plans, and alternatives sometimes offered to Subaru owners, click on Subaru Plans vs. Some Other Plans.
When you're ready to shop for the best extended service contract for your new Subaru, click on Extended Service Contract Comparisons. Then print the handy comparison form to use as a reference when discussing service contract details with your dealer or financing institution.
Contract Provisions The Subaru Plans Some Other Plans*
Wear and Tear Fully covered Often excluded from coverage
Heads and Engine Blocks Fully covered Only covered if damaged by internally lubricated part
Cause and Effect Fully covered Often excluded from coverage
CVJ Boots Fully covered Often excluded from coverage
MacPherson Struts Fully covered Cover MacPherson housing only
Replacement Parts Genuine new or remanufactured Subaru parts Parts may be used, rebuilt or generic
Claim Administration Trained Subaru factory technicians Administrator's personnel
Obligor Subaru of America, Inc. Dealer or insurance company
Rental Car Reimbursement $30/day up to $150 May provide less coverage or none at all
Towing Reimbursement $50-$100 May provide less coverage or none at all
Trip Interruption $500, if 50+ miles from home If available, may be $200, if 100+ miles from home
Roadside Assistance $100 dispatched towing, locksmith, gas delivery, tire change, battery jump, on-site minor repair, trip routing, lost key return, road hazard tire protection Availability and benefits vary or may be offered for an additional charge
Transferability $35 fee per occurrence $35-$55 if transferable or only one time in life of car
Cancellation Full refund first 90 days, pro rata thereafter, $25 fee If cancelable, pro rata or short-rate method, $35 fee
Deductible If applicable, one per repair visit regardless of the number of parts repaired One per component repaired
Surcharges Turbo 4WD, AWD, hi-tech, electronics, seals and gaskets
*Based on comprehensive marketing research of typical extended service contract providers.
Back to top
How To Be A Smart Shopper
To be sure the extended service contract you buy will do what you need it to, make sure it is a genuine Subaru product. Ask to see an actual sample of the contract and read it carefully. Reputable companies will be happy to provide one to you. Don't be misled by fancy brochures.
Important questions to ask your bank, credit union or dealer regarding extended service contracts: (To print this list and compare the benefits of Subaru Added Security to products offered by other providers, just click the "Print" button.)
Added
Security Other
Plans
Is the extended service contract you are considering a genuine Subaru product backed by Subaru of America?
Yes
Subaru Added Security is the only extended service contract backed by Subaru of America, Inc.
Does it cover wear and tear? Yes
It doesn't if it specifically excludes "low compression or gradual reduction in operating performance."
Does the contract define the term "breakdown" as, "the failure of a part to work as it was designed to work in normal service?"
Yes
If it specifies "defect in materials or workmanship," it doesn't cover wear and tear.
Does it cover cause and effect? Yes
A repair of a non-covered part due to the failure of a covered part.
Does it cover constant velocity joint boots? Yes
Ask about other "exclusions" that won't be covered by the contract.
Is rental car reimbursement available if the service department has to keep your car overnight?
Yes
Many programs require that the labor for the repair exceed eight hours to qualify for more than one day of rental coverage and allow only two days for parts delay.
Are only genuine Subaru replacement parts used for repairs?
Yes
Some non-Subaru plans allow the use of used parts.
Will you be charged just one deductible each repair visit? Yes
Many programs charge a deductible for each component that needs repair, even if it is in the same repair visit.
Are AWD, high-tech components, on-board computers, seals and gaskets included in the base price?
Yes
Many programs charge extra to cover these items.
Questions To Ask Yourself:
Who do I want to be responsible for protecting me against unexpected repair costs?
A broker, insurance company or a third party that I never heard of?
A company that may not be in business when I need them?
Or is the best choice to be covered by Subaru?
Who truly cares how happy I am with my Subaru or if I ever buy another one?
A broker, a so-called administrator or an insurance company?
Or would I rather have Subaru on my side?
Subaru cares about you!
Conekiller13 is offline   Reply With Quote
Old 12-26-2006, 07:33 PM   #9
Car: 07 STI OBP
Fav Mod: we will see soon...
well i got the extended warrenty for 6year 60K miles for 1000 on my new 07; so if they want 1500 tell them to chop down the price or you should walk!
JustinH is offline   Reply With Quote
Old 12-31-2006, 11:00 AM   #10
Most sources say don't do it. Your Subaru already has 5yr/60K miles on the powertrain which is where all the really expensive repairs will be. So to get a 5yr/60k mile extended warranty would only be for repairs OTHER than the powertrain. Brake pads are wear and tear.
lidrew is offline   Reply With Quote
