| Professional STI Driver Car: '07 STI Limited Location: Binghamton, NY Posts: 398
IWSTI Addict since: Oct 2006 Trader Rating: (0) | I'm not sure what catagory this falls under so I just decided to post it in the general forum. I have an '07 STI Limited. This may fall under the "Throttle response" problem but I'm not sure. I want to get an idea if this is a common theme accross all STI's or just my model. Whenever I'm cruising around town in say 2nd, 3rd, or 4th gear, the car is jerking. Not crazy jerky, but enough to be annoying. The car is not smooth. I'm lightly resting my foot on the pedal, and the car slows down, then jerks forward, then slows down... Stuff like this is really annoying me. I love the handing and power of the car, but little things like this bother me. This ad is not endorsed by this member. Please register or login to hide this ad. Last edited by Digitalfiend; 12-06-2006 at 10:25 AM. Reason: Added information to the title |
| | #3 |
| 1B4DSTI
Car: 06 CGM/Emotions Fav Mod: M&J Modified Location: Bensalem, PA Posts: 7,214
IWSTI Addict since: Jan 2006 Trader Rating: (10) | to the title |
| | #5 |
| S204 Racer Car: '08 335xi Coupe Fav Mod: Dinan Reflash Location: Princeton, NJ Posts: 3,549
IWSTI Addict since: Aug 2005 Trader Rating: (0) | Ya that tittle is funny. I bet it has something to do with the bad throttle programing in the 07. I suggest getting a Cobb AP and flashing stage 1 for all your 07 programming woes. Then the only jerking you will be doing wont be annoying. |
| | #6 |
| Amateur STI Driver | There are numerous threads on nasioc.com, please do a search and get Subaru technical support involved. Do a search on "2007 sti" or "sti limited" and look for the hesitation and ecu threads on the topic. Please do what everyone else is doing and call Subaru technical support and get a case # opened for you to goto the dealership and have a test drive done and make sure the tech with you is aware of the problem. Apparently 1 guy on nasioc.com is having 2 Subaru engineers (one from Houston and the other from NY or NJ fly out to analyze his vehicle for a couple of days. So Subaru is starting to pick wind of the ECU problems. The tune is the major issue and has been talked about extensively on nasioc.com and I believe on here also, the map(s) have alot of issues to be worked out with the non-linear power delivery all across the RPM range. |
| | #7 | |
IWSTI Addict since: Oct 2006 Trader Rating: (0) | Quote:
| | #9 |
| Amateur STI Driver Car: 97 WRX STI Limited U Fav Mod: none yet....still recovering from buying it. Many to come though Location: Southern Oregon Posts: 20
IWSTI Addict since: Dec 2006 Trader Rating: (0) | Well, you are not alone. My ltd #681 does the same exact thing. Only under light load, cruising, more noteable in 1st second gears, but only because of the drive ratio there. I think it is the same prob they are all having and am going to contact the suby dealer sometime. Just frustrates me to deal with mechanics as I am one who used to work at a dealer. I know this thing needs some kind of software update, but dont have the patience to deal with the 38 IQ tech that I always get. I also fear someone else driving my car. Anyhow, keep tuned here and there will be a fix ps im at 500 miles, 3 wk old and still no improvement. and mine also runs real good sometimes and not so good others as you will see noted by others too |
| | #10 |
| Silver Member
Car: 06 CGM Wingless Fav Mod: The Newest One! Location: Ra cha cha NY Posts: 3,534
IWSTI Addict since: Sep 2005 Trader Rating: (0) | My 06 does it in first gear if it is really cold out. But it is all in the throttle control for me. If I give it some more gas or the car warms up I dont get it. Also in higher gears and higher than 2000rpm I dont notice it anymore. Last edited by fourseasonsandles; 12-06-2006 at 09:36 AM. |
| | #11 |
| STI Driver Car: 07 UGM STI 121 Fav Mod: Trooper convention, somewhere else Location: North Coast Posts: 215
IWSTI Addict since: Sep 2006 Trader Rating: (0) | You are monitoring this thread as well I assume http://iwsti.com/forums/showthread.php?t=66295 Some, what would seem to be, good news from Tahoe (post #63). We'll see if this 07 ECU USDM map gets some across the board attention soon. |
| | #12 |
| Super Moderator Car: 08 DGM STI Fav Mod: My wife :) Location: Brooklin, Ontario Posts: 5,630
IWSTI Addict since: Oct 2003 Trader Rating: (0) | For the sake of keeping information in one place, I'm going to close this thread. Please read this thread regarding 2007 STi ECU problems: http://iwsti.com/forums/showthread.php?t=66295 If you still feel this isn't related, PM me and I'll re-open the thread. This ad is not endorsed by this member. Please register or login to hide this ad. |
