Old 11-27-2006, 01:21 PM   #1
Fav Mod: Do Luck CF
Unhappy 30k Service?!
Man, I just scheduled one of these and was quoted $380 without the plug replacement(just had new plugs put in it recently). This seems high to me. I do my own oil changes and tire rotations so I could have them leave that part off I guess. Is this normal?
Old 12-20-2006, 12:55 PM   #2
My dealer (in CA) charges $525 (plugs not included; I think they're good until 60K). I told them not to do the oil/tire rotation/air filter and got it dropped to $400.
francoej is offline   Reply With Quote
Old 12-20-2006, 01:03 PM   #3
abracious
Fav Mod: Track time
i think you, personally, can do most of the stuff in that service.
what exactly are they going to do for you?
Old 12-20-2006, 01:20 PM   #4
Moderator
Car: 05 Ram 3500 CTD
Fav Mod: Majin
this is the 30k service description per Subaru:
<table border="0" cellpadding="0" cellspacing="0" width="100%"><tbody><tr><td class="bg_f4 pad_5" valign="top"></td></tr></tbody></table>
<table border="0" cellpadding="0" cellspacing="0" width="100%"><tbody><tr><td class="bg_f4 pad_5" valign="top">Inspect</td> <td class="bg_f4 pad_5" valign="middle">Drive belt(s) [Except camshaft]</td> </tr> <tr> Inspect <td class="pad_5" valign="middle">Camshaft drive belt</td> </tr> <tr> <td class="bg_f4 pad_5" valign="top">Replace</td> <td class="bg_f4 pad_5" valign="middle">Engine oil</td> </tr> <tr> <td class="pad_5" valign="top">Replace</td> <td class="pad_5" valign="middle">Engine oil filter</td> </tr> <tr> <td class="bg_f4 pad_5" valign="top">Perform</td> <td class="bg_f4 pad_5" valign="middle">Replace engine coolant and inspect cooling system, hoses and connections</td> </tr> <tr> <td class="pad_5" valign="top">Recommended Performance</td> <td class="pad_5" valign="middle">Replace fuel filter and inspect fuel system, hoses and connections</td> </tr> <tr> <td class="bg_f4 pad_5" valign="top">Replace</td> <td class="bg_f4 pad_5" valign="middle">Air cleaner element</td> </tr> <tr> <td class="pad_5" valign="top">Inspect</td> <td class="pad_5" valign="middle">Transmission/Differential (Front & Rear) lubricants (Gear oil)</td> </tr> <tr> <td class="bg_f4 pad_5" valign="top">Inspect</td> <td class="bg_f4 pad_5" valign="middle">Automatic transmission fluid</td> </tr> <tr> <td class="pad_5" valign="top">Replace</td> <td class="pad_5" valign="middle">Brake fluid</td> </tr> <tr> <td class="bg_f4 pad_5" valign="top">Inspect</td> <td class="bg_f4 pad_5" valign="middle">Disc brake pads and discs, front and rear axle boots and axle shaft joint portions</td> </tr> <tr> <td class="pad_5" valign="top">Inspect</td> <td class="pad_5" valign="middle">Brake linings and drums</td> </tr> <tr> <td class="bg_f4 pad_5" valign="top">Perform</td> <td class="bg_f4 pad_5" valign="middle">Inspect brake lines and check operation of parking and service brake system</td> </tr> <tr> <td class="pad_5" valign="top">Inspect</td> <td class="pad_5" valign="middle">Clutch operation</td> </tr> <tr> <td class="bg_f4 pad_5" valign="top">Inspect</td> <td class="bg_f4 pad_5" valign="middle">Steering and suspension</td> </tr> <tr> <td class="pad_5" valign="top">Perform</td> <td class="pad_5" valign="middle">Rotate and Inspect Tires</td></tr></tbody></table>
Old 12-20-2006, 01:37 PM   #5
abracious
Fav Mod: Track time
Easily done by you:
Replace Engine oil
Replace Engine oil filter
Perform Replace engine coolant and inspect cooling system, hoses and connections ( I am assuming, I have yet to do this.)
Replace Air cleaner element
Replace Transmission/Differential (Front & Rear) lubricants (Gear oil)
Replace Brake fluid
Inspect Disc brake pads and discs, front and rear axle boots and axle shaft joint portions
Inspect Brake linings and drums
Inspect Clutch operation
Inspect Steering and suspension
Old 12-20-2006, 01:44 PM   #6
Car: 2007 SWP STI
I loved doing my 30K on my ol' 02 WRX. Really brings you closer to the vehicle. Learned a few things while I was at it too.
Do it yourself if you've got the tools and time.
John
jsmithjr732 is offline   Reply With Quote
Old 12-21-2006, 05:57 AM   #7
Fav Mod: Do Luck CF
I wanted to do it myself really, but my service advisor (guy that actually sold me the car when he was a salesman there - he and I are pretty good friends) told me that Subaru has problems with honoring warranty issues when some services aren't performed by a verifiable source, aka a dealership. I believe him - hes never jerked me around before. I pulled an idiot and forgot to bring my wheel lug lock with me when I went over there to get the service done so the brake portion was mostly untouched which really sucks because my pads are next to gone. I can't decide if I want to try to get them replaced under the 3yr/36k warranty or just buy some aftermarket pads at this point. The stock pads perform just fine for me and how I use the car - but I could sure use less dusting.
Old 12-21-2006, 06:12 AM   #8
abracious
Fav Mod: Track time
Get them replaced, then sell them here. Replace them yourself with your choice of pads.
Also- most of us have destroyed out warranty so throughly, that it doesn't matter at this point if they know when service was done. Your sig makes it look like you have done a good job of voiding most of your engine and suspension warranty. What have you to lose?
Old 12-21-2006, 08:30 AM   #9
Fav Mod: Do Luck CF
I see what you're saying but the dealership that I deal with is pretty mod friendly. They aren't going to void my entire warranty because I have lowering springs. I have done a good bit of modding, but I do not abuse my car and they know it. Kinda have to play both sides I suppose. Anyhow, you've given me some things to consider, so thanks for your input!
Old 12-21-2006, 08:46 AM   #10
abracious
Fav Mod: Track time
if you noticed, i did not say void your entire warranty, but if you change things, the dealership can easily say that caused a problem. maybe you have a nice dealer, one who will kinda turn a blind eye to the mod, but there are many that (i hear) will not.
one thing to consider- if they don't see problems with mods, maybe you should have them do your service, so that when something breaks that was modified, they will be more likely to help you out since you helped them out.
Old 12-21-2006, 08:56 AM   #11
Car: 06 WRB GOLD STI
Fav Mod: NRA Sticker
if you have receipts and proof that you did the service yourself, then you are fine, dealerships and car companies cannot entrap you into going to them, those things are just said to bring the dealerships the dough$$$$, because thats really where they make their money.
Old 12-21-2006, 08:56 AM   #12
Fav Mod: Do Luck CF
I am pretty loyal to this particular dealership. It's 60 miles (1 way) out of my way over the mountains on the TN/NC line. They have always been good to me whether is was service related or sale related. They have their own in-house performance division so I am confident that as long as I keep them happy with service and referrals, they will do what they can to keep everything on the level for me.
Old 12-21-2006, 09:00 AM   #13
Fav Mod: Do Luck CF
I have every receipt for everything I've bought for the car, even oil from Auto Zone (I'm OCD like that, unfortunately) and I log everything I do or have done to the car on my.subaru.com. I believe I have a reliable record of everything thats been done to the car to quell any possible suspicions if the time were to come that I need warranty work done. The dealership actually makes more money off of warrnanty paid work than customer paid work, and by a fairly sizable amount.
Old 12-26-2006, 03:42 PM   #14
Car: Black '05 STi
Fav Mod: Dealer delete option.
Default service
Here is a qoute for a 30k service from My shop..............
This is an estimate of 30K service to your vehicle. Check and inspects done at no charge as part of oil change.
If you have any questions at all please contact us at 503-639-5588
Thank You.
tyler@tylersautomotive.com
www.tylersautomotive.com
Estimate #36649
Tyler's Automotive
503-639-5588
2005 Subaru Impreza WRX STi 2457CC 2.5Liter H4
License Number State OR
--- Labor/Notes ---
$12.00 LUBE, OIL & FILTER CHANGE
$62.50 COOLING SYSTEM POWER FLUSH
Includes: Clean entire system with detergent. Process is thermostat operated to ensure all fluid is properly flushed. Re-fill to proper level.
$50.00 FUEL FILTER - R&R M
Serviced in Fuel Pump.
$40.50 FLUSH BRAKE SYSTEM
Includes install brake bleeder to the master cylinder and all four corners of the vehicle. We then use a three step computer controlled bleed to insure total purge of contaminated fluid and trapped air in the braking system, then road test for proper braking.
$12.50 TIRE ROTATION
--- Parts ---
$9.32 OIL FIL
$11.80 SAE 5W20 MOTOR OIL QT
$17.77 AIR FIL
$13.85 ANTIFREEZ
$15.95 RADIATOR FLUSH KIT
$28.33 FUEL FIL
$6.69 BRAKE FLUID
Note: M - Labor Database, Copyright, Mitchell International, All Rights Reserved
$177.50 Labor less discount : $40.96
$103.71 Parts less discount : $33.83
$0.00 Sublet
$14.20 Shop Sply / Enviro
$0.00 Charges
$0.00 Sales Tax (Tax @ $0.00 * 0.0000%)
$295.41 Estimate
Conekiller13 is offline   Reply With Quote
