Old 06-05-2006, 12:39 AM   #1
Car: 06 STI
Fav Mod: the driver
Default dp quesitons
hey, ive got a stock car , if i remove the dp and put it back on later will this void my warenty.
if there paint on the dp bolts ?
i want to run an aftermarket dp , but i want to keep my warrenty can i do this ? by putting it back on or is that out of the question ?
jason bouchard is offline   Reply With Quote
Old 06-05-2006, 03:28 AM   #2
Friendlys Suby
Fav Mod: M&J Modified
if u take it into the dealer and u have a aftermarket dp, im pretty sure it will
Old 06-06-2006, 02:26 PM   #3
Car: 06 STI
Fav Mod: the driver
yea im only aslking about if i take it off and put it back on, do the bolts have like blue paint or whatever to check if the bolts have been tampered with
like i deside to run an aftermaket dp, and then later i run a stock dp will it void my warrenty ??
Old 06-06-2006, 02:29 PM   #4
Car: 05 W/G STi
Fav Mod: White Headlights
Send a message via AIM to dannyc1225
its not hte bolts thats the problems, you can always paint white over them, but its hte tune that your going to need when you do the downpipe. if they see a tune then they'll throw up the flag, no reason for them to see the tune less something drastically goes wrong and they need to plug in the computer.
dannyc1225 is offline   Reply With Quote
Old 06-06-2006, 02:30 PM   #5
Send a message via AIM to straightouttajersey
running any aftermarket part will not void your warranty unless it is the directly related to the problem at hand. So you can run a DP and say a strut goes you will still be covered under warrany. However if you run a DP and you blow your motor then consider yourself S.O.L because they can argue the DP was part of the problem. Gotta pay to play..
straightouttajersey is offline   Reply With Quote
Old 06-06-2006, 02:38 PM   #6
when i took my car in for an oil change and a 5 point inspection, everything went well and still have my warranty. the guy said if it don't show on the computer we're not got to take off the dp and visually inspect it if it's catless. but i'm sure it varys at different dealerships.
808SUBsystem is offline   Reply With Quote
Old 06-06-2006, 11:49 PM   #7
Car: 06 STI
Fav Mod: the driver
ok kool, now my next question is if i get a tune , and i turn it back to stock ( including the tune on the ecu) can they tell if its modded ?
im just saying worse case if i blow the car or whatnot
Old 06-06-2006, 11:59 PM   #8
get protune on Cobb and they cant tell.
STISUBIE is offline   Reply With Quote
Old 06-07-2006, 12:05 AM   #9
Car: 08 STi, SSM
Any smart tech could tell the car has been reflashed, all he would need to do us run a check sum on the ECU and see the values don't match stock flashes. Or he could watch the boost gauge and see there was something different.
Old 06-07-2006, 12:39 PM   #10
Car: 06 STI
Fav Mod: the driver
yes but if the cobb ap is removed un married and boost psi is back to stock with stock mapps, can he still tell the ecu check sum is diff ??
Old 06-07-2006, 07:30 PM   #11
Village Idiot
Car: 04 JVP STi
Fav Mod: Blitz NUR Spec R
YES.....stop trying to cheat the system. If you want to mod your car great, more power to you, but don't expect the dealer to pay for your "play." If you can't afford to fix the things that break then don't mod them in the first place.
Chris
Old 06-07-2006, 07:31 PM   #12
Car: 08 STi, SSM
^^^What he said.
FYI, unmarrying will NOT put your stock flash back on. It puts a map that will work with your ecu, but it may not be the exact same flash that came with the car depending on what rolling revisions took place when your car was made. It is still possible to check sum the ecu but I don't know if it would stand out as being a non-stock flash.
Old 06-07-2006, 09:24 PM   #13
Car: 06 STI
Fav Mod: the driver
wtf , i wasnt asking for moral issues or anythign of the like. . . i didnt ask for imput, all i did was ask yes or no, thanks for giving me that answer.
but dont gimme extra lip . . .
