Old 05-02-2006, 01:49 PM   #1
Car: 05 sti
Default 30k service $200 yeha
Called dealer where I bought my car they said $500. Called second dealer just to see what they would say. $200 for both diffs/tranny, brake fluid change, coolant change, and belt checks. I told them no oil change, tire rotation, spark plugs, or windshield wipers. I am so glad I called around. Neil Huffman Subaru FTW!
10rtim is offline   Reply With Quote
Old 05-03-2006, 06:46 AM   #2
Car: 05 Aspen White STi
Fav Mod: S203 Titanium Exhaust
holy.. are you serious!! i bought my car from them..haha looks like i'll have to drive back down to KY for this :P
yukikaze is offline   Reply With Quote
Old 05-03-2006, 07:35 AM   #3
Car: 05 sti
Taking it over there right now. I'll let you know if there is any "funny stuff".
Old 05-03-2006, 11:55 AM   #4
Car: 05 sti
Well after dropping it off, they called me up and told me that they had misquoted me for the rear diff fluid change since it uses the lsd fluid and that it alone was $50. However, because it was their mistake he discounted the total job so the total job after tax was $243. Still pretty cheap for coolant change, brake fluid change, tranny fluid change, both diff fluid change, and the various other belt checks and things. Just lett'n ya know
Old 05-03-2006, 12:48 PM   #5
hrmm not bad i guess. at least you got a discount due to HIS (service rep's) mis-quote. thanks for keeping me updated. haven't been down there since i got the car..haha still have a letter for a free oil change :P
Old 05-03-2006, 01:02 PM   #6
Car: Black '05 STi
Fav Mod: Dealer delete option.
Here is the Subaru 30k service list:
30000 MI or 48000 KM
Inspect
Brake Hose/Line Notes
Clutch, M/T Notes
Constant Velocity Joint Boot Notes
Cooling System Notes
Inspect hoses and connections, replace coolant.
Drive Belt Notes
Fluid - A/T Notes
Fluid - Differential Notes
Inspect front and rear differential fluid levels.
Fluid - M/T Notes
Fuel Supply Line Notes
Parking Brake System Notes
Steering and Suspension Notes
Timing Belt Notes
Replace
Air Filter Element Notes
Brake Fluid Notes
Coolant (S) Notes
Engine Oil Notes
Fuel Filter Notes
Recommended service for safe vehicle operation. This inspection is not required to maintain emission warranty eligibility and it does not affect the manufacturer's obligations under the EPA's in-use compliance program. Replace at mileage interval or 30 months, whichever occurs first.
Oil Filter, Engine Notes
Rotate
Tires Notes
A tire should be replaced with a tread wear indicator appears as a solid bar across the tread. The indicators appear when the tread has worn to 1.6 mm (0.063 in) or less. Rotate at mileage interval or 7.5 months, whichever occurs first.
(S) = Service Warranty Requirement
(E) = Emission Warranty Requirement
(B) = Both Service and Emission Warranty Requirement
$243 isn't to bad..............but I'd take it to a reputable independant shop for that kind of work.............just let the dealer do the free stuff.
Conekiller13 is offline   Reply With Quote
Old 05-04-2006, 08:55 AM   #7
Car: 05 sti
Ya that info isn't sti specific.
They did all the STI 30k service stuff minus the stuff I previously stated. Found out they are a mod friendly dealer, and they are the most reputable since there are no local shops that have worked on more than one or two subarus. So 243 is the best your going to get around here unless you want to take your chances with a local shop, DIY,or drive 100+ miles to a suby shop. So I guess a can check off all those things.
Also they turned it around in 2 hours while I was at work. Neil Huffman FTW!
