Go Back   IWSTI.com: Subaru WRX STI Forums > Owners' Lounge > Warranty / Service Issues
Old 03-27-2006, 05:50 PM   #1
Car: 05|WRB|STi
Fav Mod: Cobb Stage 2
IWSTI Addict since: Aug 2005
Send a message via AIM to SoaReS
Default What do i need for an oil change?
Hey everybody,
Im just curious what i need for an oil change. A jack (not the cheap one they give us), and some jack stands maybe? Help me out here guys because idk
SoaReS is offline   Reply With Quote
Old 03-27-2006, 05:53 PM   #2
Car: '06 WRB/Silver STI
Fav Mod: Kartboy Gear
IWSTI Addict since: Mar 2006
Jack and some jack stands or ramps which ever one you have handy. An oil wrench, funnel, socket set, and some rags.
If you go to Subaru and buy a new oil filter through them you'll also get some new crush gaskets for the drain plug.
krazyk1371 is offline   Reply With Quote
Old 03-27-2006, 05:54 PM   #3
I Has a Turbo Timer
Fav Mod: Every single one!
IWSTI Addict since: Jun 2005
Trader Rating: (29)
Jack, jack stands, a rachet with sockets to take the bolts off the plastic cover, I think a flat head to take the plastic clips.....Possibley a oil filter tool to unscrew it....but usually by hand works. An oil filter, and a crush ring, and oil and your set!
Old 03-27-2006, 05:56 PM   #4
Indiatr0n in yo IWDPL
Fav Mod: Brum Brum
IWSTI Addict since: Jun 2004
2007 Postwhore King
Jack, jackstands, oil filter, crush washer (or Fumoto valve), something to collect oil in (Rev helped me with my last change, he had this nifty oil catcher/container).
Wow like 3 of the same reply. Sweet.
Old 03-27-2006, 06:03 PM   #5
Car: 05|WRB|STi
Thanks guys, I know about the tools I need lol Im not a newb that much lol but i was just curious about jacks/jackstands/ramps.
A 4 ton jack is definitely enough right? Along with 4 ton jack stands. I was thinking about ramps, but I need to find some "low" ramps.
Old 03-27-2006, 06:06 PM   #6
IWSTI Addict since: Sep 2005
Send a message via AIM to straightouttajersey
that should be fine...
straightouttajersey is offline   Reply With Quote
Old 03-27-2006, 06:19 PM   #7
Car: 05|WRB|STi
alright thanks alot guys!
Old 03-28-2006, 05:44 AM   #8
get yourself a fugimoto valve, you will love it!!
Old 03-28-2006, 05:50 AM   #9
I Has a Turbo Timer
Trader Rating: (29)
Yah your good to go......just make sure everything is tight on there....and as always, check around the car underneath, and in the engine area underneath....for any leaks, remains of liquids...this way, when you change the oil again next time, you can remember if you had a leak somewhere, and fixed it or what not, you know what to look for. Plus its always good to check everything just to make sure. I am a very cautious person, so thats just instinct for me lol.
Old 03-28-2006, 05:52 AM   #10
Car: EZ-GO
IWSTI Addict since: Feb 2004
^^^^^^ Its Fumoto
I got one myself... I love it.
Hawaii_guy
Hawaii_guy is offline   Reply With Quote
Old 03-28-2006, 07:15 AM   #11
Car: 05 STi WRB w/silver
Fav Mod: Defi
IWSTI Addict since: Mar 2005
I need to get me one of those valves.
Fast_STi is offline   Reply With Quote
Old 03-28-2006, 12:57 PM   #12
DOMINATOR
Fav Mod: Strut Clunk
IWSTI Addict since: May 2005
Those valves are sweet! I'm definitely doing my oil changes from now on. I needed one in a rush a few weeks ago cuz I had burned through most of my oil (120+ for a couple hours did the trick) and was going out of town and the hick at jiffy lube didn't even know what kind of car it was, not even that it was an impreza.
Old 03-28-2006, 01:25 PM   #13
Fav Mod: FYI, I'm a dude
i'm on jdm pinks and have been able to do the oil changes without ramps or stands. there's enough room to do it with the car on the ground if you're lazy like me
Old 03-28-2006, 02:51 PM   #14
which oil filter do you guys use? i heard the ones you get from subaru can sometimes leak, do u guys use any other brands?
crim_ is offline   Reply With Quote
Old 03-28-2006, 02:53 PM   #15
Car: 04 WRB/G STi
Fav Mod: Sz49 + Meth
I use K&N filters.
Boostpimp is offline   Reply With Quote
