Old 03-14-2006, 10:13 AM   #16
Car: Waiting for the STI
Fav Mod: Driving My Car
15k mile service...
  • Replace Engine oil
  • Replace Engine oil filter
  • Inspect Disc brake pads and discs, front and rear axle boots and axle shaft joint portions
  • Perform Inspect brake lines and check operation of parking and service brake system
  • Inspect Clutch operation
  • Inspect Steering and suspension
  • Perform Rotate and Inspect Tires
www.mysubaru.com
sebtarta is offline   Reply With Quote
Old 03-14-2006, 04:53 PM   #17
Car: 05 CGM STI on 57F br
Fav Mod: stage 2
This may help for one of those bullets.
C: INSPECTION
While pulling the parking brake lever upward, count
the notches.
Lever stroke:
7 to 8 notches when pulled with a force of 196
N (20 kgf, 44 lb)
If not as specified, adjust the parking brake
D: ADJUSTMENT
1) Remove the console cover.
2) Forcibly pull the parking brake lever 3 to 5 times.
3) Adjust the parking brake lever by turning adjuster
until parking brake lever stroke is set at 7 to 8
notches with operating force of 196 N (20 kgf, 44
lb).
4) Tighten the lock nut.
Lever stroke:
N (20 kgf, 44 lb)
Tightening torque (Lock nut):
5.9 N•m (0.6 kgf-m, 4.3 ft-lb)
Old 03-14-2006, 07:00 PM   #18
Car: 05' STi
Fav Mod: JDM Fogs
Originally Posted by yoojeankim
ugh... is this sarcasm? of course i change my oil every 2.5k miles -.-
It was only semi sarcastic. I figured you would changer you oil more then that. But you never know. Some people don't really believe it car maintenance unless it's actually needed.
You could be running amsoil, in which case you would only need to change the filter ever 3000 or so.
Old 03-14-2006, 07:43 PM   #19
This is what they replied they do for the $223 or whatever it was...I asked for a price without oil change, I just went to mobile1.
Response to my email asking them what is included because it seemed expensive for a few checks and inspects with a tire rotation:
This a complete list of the services included in our 15000 mile service (minus oil change). This list of services is recommended for the best performance and safety of your vehicle.
Check tension and condition of all engine belts and adjust if necessary.
Check oil level in rear axle--also differential if applicable.
Check or adjust clutch if equipped.
Inspect wheel brake cylinders and dust boots for leaks.
Visually inspect fuel tank, lines and connections for leaks.
Check all fluid levels.
Check front and rear drive axles and boots.
Check front suspension.
Replace PCV element.
Replace spark plugs if necessary.
Check operation of heating/air conditioning system.
Check rear defroster operation.
Check power steering gear lines and hoses.
Check exhaust.
Lube latches and hinges.
Check seat belts for safety.
Check turbo operation if equipped
Check or adjust idle RPMs.
Inspect all vacuum fuel and vapor lines, hoses and connections.
Check A/C performance.
Change air filter.
Rotate and balance tires.
Perform four wheel brake inspection.
Adjust parking brake cable(s).
Road test vehicle to check performance.
If you have any questions, please call me.
Seems like a few more items than just the my.subaru.com maintenance.
STiMUL8tion is offline   Reply With Quote
Old 03-14-2006, 08:37 PM   #20
Car: 06 Steel Gray STI
Fav Mod: COBB Springs
I got the 3 year maintenance plan with my car so all that stuff is free for me!!!
Sonicbooost is offline   Reply With Quote
Old 04-04-2006, 04:33 PM   #21
Car: 02 RSX Type S
Fav Mod: 4300 H.I.D. Kit
Check exhaust.
Change air filter.
That's an awful lot of CHECKING that you could do yourself.
Big Cam is offline   Reply With Quote
Old 06-02-2006, 11:14 AM   #22
Car: 06 STI AW
am i screwed if i did not keep all the reciepts. i have some but not all im only at 12000. ive been loggin it on my subaru though.
jollib is offline   Reply With Quote
Old 06-02-2006, 11:49 AM   #23
Car: 05 WRX STi
I paid ~$150 for my 15k service w/ a 10% coupon. I also did not get my cabin air filter changed.
www.mysubaru.com has maintenance coupons.
PeterC0523 is offline   Reply With Quote
