Go Back   IWSTI.com: Subaru WRX STI Forums > Owners' Lounge > Warranty / Service Issues
Old 01-25-2006, 06:54 AM   #16
Car: 05 WRX STi CGM/Slver
IWSTI Addict since: Mar 2004
Sorry I don't have a picture of it flipped on my car but if you search there are a couple posted. If you look at my pictures above you can see the sway bar end links attached to the lateral links. They should look like that, pointed up. If your bar flips the sway bar end links will be pointed down and bent over the lateral links causing the damage I was asking about.
Also to add to my question about the dealer's responsibility, they told me to drive around for 5 days with the sway bar flipped while they ordered the end links because they didn't want to give me a loaner car. So they definitely made the damage worse. If it were up to me I wouldn't have driven the car with a flipped sway bar.
Pyrex is offline   Reply With Quote
Old 01-25-2006, 09:04 AM   #17
Car: 05, Subaru Impreza W
IWSTI Addict since: Oct 2005
Hmmm...I should probably keep an eye on mine since I pull into a parking lot, making one rear tire leave the ground, several times a week.
BlueGold is offline   Reply With Quote
Old 01-25-2006, 10:02 AM   #18
Car: 05 Subaru WRX STI
Fav Mod: Spec C roof vent
IWSTI Addict since: Jan 2006
My car was stock when it happened. It was my driveway. It caused me to "tip" while going up in. The rear wheel would "float" before coming back into contact with the driveway. If this happens with your driveway, I'd be looking into it if I were you.
STImachine is offline   Reply With Quote
Old 01-25-2006, 11:02 AM   #19
Banned
Car: '05 Subaru WRX STi
Fav Mod: Anything that enables me to go faster!
IWSTI Addict since: Dec 2005
Thanks for the post, bro. I'll check out the pics.
'05 STi is offline   Reply With Quote
Old 01-25-2006, 01:04 PM   #20
Car: 06 & 07 STI WRB
Fav Mod: PDX PROTUNE
IWSTI Addict since: Sep 2005
On my 04, I flipped my twice in one week. Only one side though. It was caused by the driveway at work. The car would slope to one side with the fender just about touching the one tire and having about 4" clear on the other side. I finally had to get some Perrin end links and a new swaybar as well. I got the dealer to install them under warrenty. Now I have an 06 which I've left the suspension stock and haven't had any problems yet.
STI-TOM is offline   Reply With Quote
Old 01-27-2006, 04:33 AM   #21
Interesting...I just checked mine this morning and they looked good to me. No sign of flipping....yet.
Old 01-27-2006, 04:40 AM   #22
woz
Fav Mod: intake hack=free
Mine did the same on my 04. dealer didnt warany them either, so now I have endlinks in the shape of an "C". Before I refliped them the body sat with a lean.
woz is offline   Reply With Quote
Old 02-13-2006, 10:31 PM   #23
Car: 08 STi w' BBS
Fav Mod: Big Turbo
IWSTI Addict since: Jan 2004
EXACT same thing happened to me at an autocross last year. Wouldn't replace the lateral links either, but oh well, its a solid chunk it hasn't failed in a year.
Antimullet is offline   Reply With Quote
Old 02-14-2006, 07:21 AM   #24
Car: '04 JBP STi
Fav Mod: Whiteline Steering Bushings
IWSTI Addict since: Feb 2004
it doens't just happen from driving obviously, they can flip when you jack the car up and then when you set it back down. Mine flipped when my suspension was completely stock, the end links looked like C's they were bent so bad. I have hotchkis endlinks now still w/ stock swaybar and have had no issues.
drdome99 is offline   Reply With Quote
Old 02-14-2006, 07:24 AM   #25
Car: '04 JBP STi
Sittin sidewayz y0 that is hot down souf
