Old 09-21-2005, 05:44 PM   #1
Default clutch recall?
im posting this here and in warranty thread to get some more info on this.. is it true??
http://www.sqc-ny.com/tech/tech.asp#
then in the subcat choose transmission topic
like i have said before my search doesnt work so no flaming
rob142sti is offline   Reply With Quote
Old 09-21-2005, 05:48 PM   #2
just seeing if this is true or not ... no flaming my search doesnt work.. damn cookies
but anyway
Old 09-21-2005, 05:53 PM   #3
Car: 05' STi CGM/Silver
Fav Mod: Recaro Sports
doesnt apply to me, but id never heard about it so thanks! thought for a sec there i might be getting me a free clutch
STi05' is offline   Reply With Quote
Old 09-21-2005, 05:58 PM   #4
sorry man.. my eyes lit up when i saw it.. i fall under that specified vin so im hoping this is real!!!
Old 09-21-2005, 06:02 PM   #5
Fav Mod: Track Time
Just missed it but I have a friend it would include. Thanks.
WE_R_ND is offline   Reply With Quote
Old 09-21-2005, 06:34 PM   #6
anyone ???
Old 09-21-2005, 06:44 PM   #7
Car: 04/08STI 95SVX 86E30
Trader Rating: (53)
Well, my vin is below the indicated numbers, but I did not see a recall notice on this anywhere else. It also doesn't express exactly which tranny that I could tell. The WRX and STi are both GD chassis.
Turninconcepts.com is online now   Reply With Quote
Old 09-22-2005, 06:39 AM   #8
Car: 2006 Subaru
Fav Mod: JDM "Baby In Car"
I couldn't find the subcat
hook me up.
iTSTi is offline   Reply With Quote
Old 09-22-2005, 08:23 AM   #9
Default directly
Transmission Issue on Deceleration (GD)
Vin. Numbers & Symptoms.
- Rattle under de-cel usually in 3rd gear, 4000-2000 Rpm usually.
- Increase rear tire pressure 4 psi, decrease front 4 psi, should get louder.
Do the opposite, should get quieter.
- If the last six digits of you VIN are lower than 515611, you have the old type clutch from the factory. If your motor number is less than 331738 (white tag, hard to find), you have the old clutch from the factory.
- The official subaru tech line fix, is IF your car HAS the OLD clutch parts as indicated by the VIN and Motor numbers, IT IS TO BE REPLACED BY THE FOLLOWING PARTS:
30100AA790 - Disc
30210AA530 - Cover (pressure plate)
12342AA050 - Flywheel
800610740 - Bolts
Old 09-22-2005, 05:21 PM   #10
Car: 05 STi, 04 M3, 90 Sp
Fav Mod: Clear bra
So this applies to ANY GD, even an STi?
Looks like my '05 falls under the recall numbers.
smurfm3 is offline   Reply With Quote
Old 09-22-2005, 05:32 PM   #11
me too .. im awaiting an email from the owner of that site to give me more details on which model it applies too... subaru put me on hold for an hour about the subject.. but i sure can use a new clutch!!!
Old 09-22-2005, 06:34 PM   #12
Car: '04 WRB
Fav Mod: A working ECU...
I fall under that, but haven't noticed this problem. I'm sure if you brought your STi in, the tech would check first to see if the noise is present by changing pressures. If not, no fix for you!
Old 09-22-2005, 06:51 PM   #13
thats true but i really havent been able to listen for anything (exhaust too loud) but even if i were, STis make way too many strange noises anyway so i wouldnt even know what to listen for..
Old 09-22-2005, 07:33 PM   #14
yea i just noticed my clutch makes a sqeak sound evertime I press it. I can only hear it if my radio is off and Im not on the gas. i gotta go in the garage and see if im on the list.
12000 miles
normansti is offline   Reply With Quote
Old 09-22-2005, 07:35 PM   #15
yup im on it
