Old 05-22-2008, 05:47 PM   #721
Car: 05 STi CGM Stg2
Default Re: Rear Strut Clunk Log
Originally Posted by hks_sti View Post
ok so ive had this "strut clunk" for a while now and its really starting 2 get annoying its getting to the point were i have to turn the radio louder to not hear the dam things it usualy occurs during slow speeds like taking off or backing up or slowing down ive taken it to the dealer twice n have complained about the noise but they still pretty much keep shuting me down by saying it can only get replaced under warranty if they are leaking or cracked idk what to do are there aftermarket ones i can buy that will not have this clunk in the futer any info 2 sove this problem please let me know.............thanks
they r BS'ing you. Tell them you wanna talk to your regional warranty rep. Call SOA, if its making that much noise its un acceptable and should be warranty. Tons have had it replaced for noise, you can easily print those posts and show them thats its replaced under warranty. Otherwise find a different dealer.
BTW a close friend has an 04 and hers is noisy as hell as well. I will take a ride in her car one of these days...apparently 04 owners complain abt the level of discomfort a lot more than 05+
Good luck
-Akshay
Old 05-31-2008, 11:04 AM   #722
Car: 2006 AW STi
Fav Mod: Stage 2...so far...
So would new springs and struts help or hinder this problem that I am having with "clunking?"
biker921 is offline   Reply With Quote
Old 05-31-2008, 04:26 PM   #723
New struts will not clunk right away, they will last a while before clunking.New springs can help if you put something progressive like prodrive, Eibach.
You could get the ever popular Ohlins struts + RCE springs RCE blacks if clearance is an issue or if you live in snowy areas. Otherwise get the RCE yellows for a nice lowered ride plus great handling. I have no direct experience with these but a lot of guys are running them and tracking them and only good things are said.
If you want for the similar price goto coilovers like RCE Tarmac2's and TiC's (AST coilover)
Other than the above options I cant really recommend anything else. Replacing something that will clunk again is pointless unless you get a smoing deal on some almost new struts. Might aswell upgrade. But be warned most struts for an STi is inverted style which have a stiction issue which is inherent of the design. When you stop the car will feel like the shcks reeased a bit. There will be some ocassional clunk but many of these upgrade parts I mentioned come with lifetime warranties so if you havent hopped a curb etc you will be able to get them rebuilt for free. Rebuilds are few and far between.
Its not chea but assuming you are a car enthusiast, this is the best opportunty to upgrade. BTW I am no expert like others on the forum but I have done tons o research and I do track/work on my car.
Goodluck
Old 05-31-2008, 04:31 PM   #724
Car: 2006 AW STi
Cool, thanks. I'm planning on running Crucial Racing springs with some koni inserts
Old 06-01-2008, 07:50 AM   #725
Didnt know there were inserts availble for the 05-07 STi's now.
Good luck
-Akshay
Old 07-12-2008, 11:36 AM   #726
Car: 04 wrx sti
Fav Mod: the wh0le f'n car
gettin my done as we speak .. ****s so annoyin.. my co-worker had to have his changed at 15,000 miles
stadium_statuz is offline   Reply With Quote
Old 07-12-2008, 07:57 PM   #727
Car: 06 STI - WRB, 05 LGT
Fav Mod: hella supertones
Send a message via AIM to SubaruFlamingo
I have 13,500 miles on my 06 (driven for a little over 2.5 years) and I think I'm getting this, especially in the front left and rear right. The front left only occasionally (but when it happens it happens for the entire drive.. sounds like a series of *pops*), and the rear right is basically all the time and it sounds different but sounds like its sticking or something.
The car feels fine, so I am going to wait for 2 weeks until I bring it in for the 15k service and hopefully they can replace/fix this under warranty... as I am planning on selling the car soon!
SubaruFlamingo is offline   Reply With Quote
Old 07-14-2008, 11:09 AM   #728
Car: 2004 STI PSM
My first set of rear struts were replaced under warranty at 26,000 miles,
and my second set replaced under extended-warranty at 52,000 miles.
Now at 80,000 they are clunking again...shocking !
sti04dude is offline   Reply With Quote
Old 07-14-2008, 06:43 PM   #729
Yeah I hear the 04 guys have lots more trouble than the others...or maybe its just what I think
Just put coilovers man like TiC or T2's I think Myles has another lower range of coilovers for street use. 3 bad sets is pretty bad
Old 07-22-2008, 11:21 AM   #730
Took it in and both fronts are being replaced under warranty. I guess what I thought was the right rear was the right front. If you are hearing this sound and your warranty is almost up, make sure you go in! It's odd this is a recurring problem Subaru didn't (hasn't?) fixed.
Old 07-27-2008, 11:46 AM   #731
Car: urban grey 07 sti
Fav Mod: physicist
Originally Posted by LuVJuGGs View Post
Stiction, inherent feature of inverted cartridges...it must kinda feel like the rear struts release a tad when u stop
yes, stiction (static friction is an issue here) close examination under collimated monochromatic light shows many waves in the surface of the outer tube (it's got a name but i don't know what it is!) near where the that tube and the seal interface (when the car's loaded of course).
people wanted to blame KYB for having too soft material on the tube. i bought a PSS9 bilstein kit and i have the same problem. mr. luvjuggs is indeed correct.
it's a total bummer, though, isn't it?
sciroccoR is offline   Reply With Quote
Old 07-27-2008, 12:32 PM   #732
Car: 04 wrb sti sil/bbs
Fav Mod: air conditioning...
Send a message via AIM to GCtoSTI
so your screwed if you already have lowering springs on the struts...
i bought the car lowered... dammmm..lol oh well
i wonder how the kyb's hold up...
GCtoSTI is offline   Reply With Quote
Old 07-27-2008, 04:38 PM   #733
Its just noise...i just put brand new pss9's we'll see how long they last...everyone who reads up on this issue learns there is little to completely eliminate this...I think any car with these inverted design strut have this issue...its a con amongst many pro's
Old 07-30-2008, 11:30 AM   #734
Car: 05 sti
Fav Mod: shock knock
just bought my sti used with 60k, its lowered.. has the clunking problem.. saving for new suspension..
chitownrida is online now   Reply With Quote
Old 07-30-2008, 02:01 PM   #735
what kinda springs are n it currently?
