Old 04-08-2008, 09:37 AM   #691
If in doubt, flat out
Trader Rating: (23)
Default Re: Rear Strut Clunk Log
Originally Posted by EBTurbo View Post
I used to work at the dealer and i would see this concern at least twice a week. from my experience with it, you had to replace both the strut and hat to stop the noise. the noise will come back but, it would be considerably longer when both strut and hat were replaced. from my dealing with factory Subaru field representatives and training instructors the problem lies in the rear strut geometry, not the seal.
EB Turbo
Interesting. That makes sense that it was a geometry problem, otherwise it wouldn't have taken them 4 model years (for the US) to remedy it. A redesign of the geometry would be costly. Temporarily alleviating the problem is cheaper although not very customer friendly. It leaves all 04-07 owners having to replace their struts regularly.
On the flip side, it will be interesting to see if Ohlins FPS owners begin to experience clunk as the miles add up. If they don't, then it's not a geometry problem, it's a stock strut design problem. Ohlins FPS don't change the geometry of the rear suspension.
Old 04-09-2008, 06:09 PM   #692
Car: 05 STi CGM Stg2
Well any inverted strut will have some stiction, even in a porche. So the strut design needs to accomodate for the difficult application IMO
Old 04-09-2008, 06:52 PM   #693
Trader Rating: (23)
you're talking about old porsches i assume?
Old 04-09-2008, 06:58 PM   #694
Car: 05 OBP WRX STi
Fav Mod: Right Foot
I got mine replaced by the dealer for free, 200 miles before my warranty went out
Now the replacement struts have a 1 year warranty.
atomicfire is offline   Reply With Quote
Old 04-14-2008, 08:49 PM   #695
Car: blue 04 STI
Fav Mod: stage 2 protune!
Send a message via AIM to russtg224
My 04 was clunking at 45k, I just jacked it up last night, lifted the dust covers up sprayed the strut shafts with some white lithium grease and they don't clunk anymore even after 500+ miles
russtg224 is offline   Reply With Quote
Old 04-14-2008, 08:51 PM   #696
Trader Rating: (23)
500 miles? Lithium grease is water based. Report back in a few thousand miles.
Old 05-05-2008, 10:27 AM   #697
Car: Silver 05 STi
Fav Mod: Stage 2
I have heard of guys packing the cartriges with ATF as a dampener instead of grease..
any thoughts on this?
Misanthrope789 is offline   Reply With Quote
Old 05-05-2008, 10:36 AM   #698
Car: UGM 07 STI
Fav Mod: Learning to drive better
Send a message via AIM to Urban07STI
Mine stopped clunking....really strange. For most of the winter it was consistent going slow. I got the clunk after 11K miles in my 07, now at ~14K it's not clunking anymore. I did jack up the rear end the other day, both tire off the ground, maybe something to do with it?
Urban07STI is offline   Reply With Quote
Old 05-05-2008, 11:04 AM   #699
Car: 05 Subaru WRX STi
That had everything to do with it. The struts got relubricated. The clunk will come back.
rasetsu is offline   Reply With Quote
Old 05-05-2008, 11:24 AM   #700
Car: UGM 07 STI
Excellent......haha, can't wait. Maybe I'll have the dealer lube them up. I'm nearly positive it won't clunk if I bring it in....
Old 05-05-2008, 11:31 AM   #701
Trader Rating: (23)
I assume you're talking about replacing the oil in the actual damper with ATF. This does not seem possible or at least easy because the dampers filled with nitrogen gas and sealed.
Old 05-05-2008, 12:13 PM   #702
It will clunk the dealer will try to blame it on something else if you have any mods. Jack up the car, lift up the dust boots and massage globs of grease onto the struts yourself. Not worth a trip to the dealer.
Old 05-05-2008, 03:09 PM   #703
Trader Rating: (23)
It's far better and will last longer if you disassemble the struts and repack them.
Old 05-05-2008, 05:17 PM   #704
just drive it through some twisties and drive it like it was the monte carlo rally...if ur clunkin means ur not driving it like an STi
Work them struts!!
Old 05-05-2008, 05:33 PM   #705
Car: 2004 "JCT" JBP STI
Fav Mod: 35r
Does the clunk cause any harm, is it detrimental to the car in any way? I have a pretty severe clunk that I experience under acceleration and braking, and occasionally when shifting spiritedly. . . I knew of the problem and thought it was just noise, is it hurting the car not to fix it?
BigTrippin is offline   Reply With Quote
